Question about Ovens
Oven racks in my self cleaning oven /get back shine
Help i left my oven racks in my oven which is self clean but i noticed that my racks have no more shine to it ! how can i get back the shine?
If you have the time and the energy use a paste of baking soda and a brass brush (from home improvement store) or a piece of aluminum foil. You will have to scrub for hours, but it does work!
Posted on Jan 07, 2011
How can I clean the pullout racks and side racks of self-cleaning oven?
The racks may have to be removed, if possible, and cleaned separately using oven cleaner.
Feb 18, 2016 | Ovens
Electrolux Icon Oven self cleaning won't start- the lock button keeps flashing. Yes, the racks and rack holders are removed.
Good Afternoon Friend,
I understand that you are having trouble with your Electrolux Icon oven, model# E30SO75ESS, and running the self-clean cycle. I see that the lock button keeps flashing and that you have the racks and rack holders out. I suggest following the steps below to run your self-clean cycle:
    1) Place the rack holders and the racks in your oven.
    2) Reset your appliance, by shutting the power off at your homes circuit breaker, for 3-5 minutes.
    3) Restore power.
    4) Reset the clock, by pressing the "Clock" button then press the number "2". Enter in the time of day, and then press the "Clock" button again.
    5) Start the self-clean cycle with the racks in your range. This is to make your oven recognize that the racks are in the oven.
    6) Take the racks and rack holders out and start the self-clean cycle again.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your oven status has changed successfully.
    -Best Regards-
    WP
May 18, 2014 | Electrolux ICON Designer E30SO75ESS Oven
I removed all the racks from my upper oven (including the side racks) to self-clean and am getting the "remove racks" light. I've cleaned the oven before and never had this happen. The...
There is a button on the top receiver bracket on the left side... when you take the rack support bracket out you will see it. Take a damp sponge and go over that area, pressing the plunger/button in several times. That should do it. Sometimes grease build up can prevent the button from popping out all the way, so the oven thinks that the racks are still in there.
Aug 21, 2011 | Electrolux ICON Designer E30SO75ESS Oven
Do we leave the racks in the oven while cleaning it ?
Hi.
I assume you are referring to the "self-clean" function of your oven, in which case, the answer is no. All racks and the broiling pan, etc should be removed from the oven before initiating self-clean mode.
I can't give any specific instructions for the self-clean mode on your oven as you have not specified a brand or model number. If you need any further assistance, please post back with these details.
Please note: The high temperatures generated during "self-clean" have been known to cause the door locking mechanisms on many ovens to become stuck in the closed position. This often requires a service call to rectify the problem. If you are planning to use the self-clean before cooking your Christmas meal tomorrow, please bear this in mind. There is little chance of getting a service call between now and then.
Hope this helps.
Happy holidays!
BElectric.
Dec 24, 2010 | Ovens
How do i turn on the self clean? i punched clean and it told me to take the racks out. i removed the racks, but it keeps telling me to remove them and will not do anything else?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 14, 2010 | Electrolux Ovens
My oven racks don't fit after self cleaning the racks are to narrow or oven is too wide now
No.... the heat warped the sides of the oven and wrecked it......you try and beat the sides back out.... either way you have a junker now....
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Dec 12, 2010 | Ovens
GE Monogram Trivection - self-clean cycle with oven racks in
Hello- First off, do not use 'self clean', or as most Techs call it: "Self- Destruct".  This 'feature' cheerfully sold by the salesman destroys more oven and range components than any other failure. Now- the racks had a thin layer of grease on them when the oven tried to turn stuff inside the oven to ash.  The grease is now a hard rubbery coating on the surface of the rack.  To solve this problem, you must determine by observation, where the rack touches the sides of the oven. These contact areas need to be cleaned thoroughly with scotchbrite and a small portion of oven cleaner. Make sure you use gloves. Sliding rack in and out to 'mark' these small spots works pretty good.  Once cleaned and wiped down, they should work fine. I recommend cleaning by removing as much 'stuff' by scraping and wiping down with moist cloth.  Turn on to 450deg for 30 min.  Much safer, less costly.                                                       Please acknowledge this posted solution if helpful.  Have more info if needed-  Thanks  -Ed
Mar 24, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
I have lost my book, and need to use the self cleaning oven feature. What is the process?
The oven should have a self cleang button, just remove the oven racks, because the heat will turn the shinny racks to a dull shine, and press the self cleaning button, it will go through the cleaning cycle, the cycle takes about 3-1/2 - 4 hours
Oct 30, 2009 | Ovens
Electrolux Icon Oven won't self clean - "Remove Racks" displayed
I was getting the remove rack error until I finally figured out what it wanted me to remove. When you say you removed the rack supports, do you mean just the sliding parts or the whole side metal rack support? At first I thought they were bolted in, but I read somewhere that they come out, too. Upon further investigation, I found the rack supports just slide into the side walls at 4 points. I had to use a little force to pull them out, but they came out and my oven is self-cleaning as I write this. I just thought I would share in case you or others haven't figured it out yet. Now I will just have to see how hard it is to get them back in...
Nov 01, 2008 | Electrolux ICON Designer E30SO75ESS Oven
Ovens Logo
1,338 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
