Question about Zenith B25A02Z TV
My newish logic tv
I recently brought a logic flat screen tv.its all up and running but there is one problem.i'm not getting any sound. when i adjust the volume i it says next to the volume bar that i'm adjusting the headphone volume. now in this situation any normal person would turn to thier manual but the thing is the tv was one of the ones u would look at in the shop so it didnt come with box or manual. any idea?
  • 99 Answers
Re: my newish logic tv
It looks like you have a headphone jack that normally switches back to speakers when the plug is removed.Your plug is stuck in the phone position. Try to plug in a plug in and out to release the contacks.
good luck---------------------------tomtaso
Posted on Dec 01, 2007
0 characters
3 Points
RCA entertainment series TV does not show the entire image
Check the picture settings. It sounds that the picture settings to TV is Zoomed.
May 29, 2012 | Standard (CRT) Televisions
Hello, hopefully you can help me. I just brought a used sony wega kv-27fs13 27 flat-screen tv. But when I put the cable wire in the TV it says No Signal. Do you know what the problem could be?
Jul 23, 2011 | Sony KV-27FS13 27" TV
My tv the screen there are line and sometime no draw?
If there are lines on the screen [parellel lines across the screen horizontally, at about an inch or so apart], your tv needs screen adjustment. Its screen voltage is now high. It can be brought low by adjustments. There is a screen adjustment control, usually integrated with Line Output Transformer. If you know, you yourself can adjust this. It is an internal adjustment and need to open the back cover of the TV. Don't use your TV for long time without rectifying this problem. It may get picture tube damaged. The electron guns inside the picture tube neck will get red hot and its emmision will be reduced.
Oct 18, 2010 | Sharp 32C241 TV
Why is my sanyo tv flashing green, blue, and red ?
i turned it on nd it was still like that nd i gt more mad. i was gna throw the remote bt i presed the menu button randomly once or twice i dunno bt it came back(normal tv)
hope that helps
Apr 11, 2010 | Sanyo DS31520 31" TV
Wow - same thing happened to mine
I woke up one morning and the tv was dead, only a dark blue screen. remote works and that's it. i was thinking about doing the rca reset but don't know how to. this tv is only 2 years old when i brought it. I think it's time for a new flat screen with what the techs are asking for to fix it.
Jul 30, 2009 | RCA 32V420T 32" TV
SanyoTV-blk screen w/thin line of light across screen great sound
Your Vertical Amp is probably Blown (bad) , but before you change that check all capacitors around the vertical amp IC and / or resolder resistors and diodes around vertical amplifier.
And NO it is NOT the Picture Tube
Good Luck
Apr 18, 2009 | Sanyo DS27820 27" TV
I have a 10 year old Zenith Color Tv the screen is blurry
It may need a focus adjustment or the CRT socket needs to be replaced. Look in from the inside for this parts.
Feb 09, 2008 | Zenith SY2751Y TV
Thin Red Lines on Top of Screen
Sorry, that is common for generic replacement xformers for
your make / model . There are some adjustments to minimize
the effect in servicer can try turning down the
screen control a bit....................T.
Dec 21, 2007 | RCA F36650 36" TV
Sound problem in Panasonic TV bought in Poland
your friend is right you require pal system to run tv properly.
on the back side of your tv there might be switch pal/ntsc
if that system change over switch is not there then you are helpless
good luck.
Oct 17, 2007 | Standard (CRT) Televisions
Zenith B25A02Z TV Logo
556 people viewed this question
Top Zenith Standard (CRT) Televisions Experts
matt martin
matt martin
Anastasio Benjou
Are you a Zenith Standard (CRT) Television Expert? Answer questions, earn points and help others
