Question about Dell Inspiron 6000 Notebook
Dell laptop 6000 won't shut down
When you log off or shut down
it stays on all time
    Sergeant:
    Champion:
  • 327 Answers
You might have to put in the reboot disk ..because there is a virus out there that does that ..i know i had it i had to reboot my computer and download the new video drivers for it when i was done rebooting the computer ...i know laptops do not most time come with reboot diskes but if you made one you sould be able to do this if not find someone with a desk top and use there disk ..make sure same OS
Posted on Jul 15, 2009
  • 744 Answers
Hi..
If the computer overheated, it could have shut down. If the inverter broke, it could give invalid voltages overloading the computer and possibly shorting the motherboard. contact ur repair shop..
thank u
rate me!!!
Power up laptop dell 1501 ,stays on until you logg on then after log on and programs load all power is lost
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Feb 15, 2012 | Dell Inspiron 1501 Laptop
Tip
Battery won?t charge and AC adaptor not recognized
I have a Dell Inspiron 6000 that just turned two years old.
After one year, my dell 6-cell battery started to falter, so Ipurchased a new 9-cell battery. This worked fine until a couple ofmonths ago when I noticed that my 65W adaptor was frayed. I bought anew 65W Dell Inspiron 6000 ac adapter andit worked well for about a week until I noticed that my battery wasn’tcharging at times. If I was patient, or unplugged the adapter andplugged it back in, the battery began charging and all was saved.
dell-inspiron-6000-laptop-battery.jpg?w=200
This lasted only a short time until my Dell Inspiron 6000 batterywouldn’t charge at all for long periods of time, and sometimes thecomputer wouldn’t turn on, even if plugged into the wall. I thought itmight still be the adaptor, so I borrowed a fully functioning 90W Delladapter from a family member to test the system. This worked better,but still not great.
When I removed the battery and started only fromAC power, the functionality was also intermittent. Usually, if thecomputer actually started, I received the start-up error “The Inspiron 6000 AC AdapterType could not be determined, etc. etc. etc.” After pressing F1, thecomputer booted, but if the battery wasn’t in, the computer didn’tusually last long before shutting off. Unsure if maybe the battery wasthe problem, I put the 6-cell Inspiron 6000 batteryback in, and it too wouldn’t charge, although (together with the 90Wadapter) my computer would at least start more consistently if pluggedin. The error remained however, and sometimes the system stopsrecognizing power and switches to my ever dwindling battery power untilthe adapter is recognized again.
The problem is with the jack on the motherboard inside our Inspiron 6000’s. This is the jack you plug your power plug into on the back of the laptop.
Somehow the jack gets worn and does not make correct contact withthe laptop so the Laptop does not see the power supply as a legit Dellbrand. So the powersupply will not charge the laptop battery and run the laptop at the same time.
DC power jack repair guide. Do-it-yourself instructions.
Modern laptops are all sold with built-in wireless laptop ac adapter.Some power notebooks used by corporate road warriors will have powerfulcellular adapters that connect the laptop to the Internet via the cellphone infrastructure
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with dell pa 12,dell e1505 and Dell Inspiron 6000notebooks. If your laptop is out of warranty, then you can fix theproblem by resoldering DC-IN jack on the system board. If it’s stillunder warranty, it would be fixed at no charge to you. Problem symptoms:
  • Laptop randomly shuts down without any warning.
  • Power LED and battery charge LED start flickering when you wigglethe power cord or the AC adapter tip on the back or your laptop.
  • The battery will not get charged.
  • When you plug ac adapter for laptop, the laptop appears to be dead and there is no LED * activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. dell pa 12 and Dell Inspiron 6000 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system laptop board witha magnifying glass. In most cases you get the power problem because ofa bad connection between the DC jack and the system board, you’ll see acrack between the DC jack connector and the system board.
on Jan 22, 2010 | Computers & Internet
Dell Inspiron 6000 powers up, caps lock flashes 9 times, then laptop shut down. Why???
Unplug power cord from laptop, remove battery from laptop. Open memory access panel on the bottom of the laptop. Remove memory module(s) (SO-DIMM). Plug power cord back into laptop. Turn laptop on (with the memory removed), the caps lock and scroll lock LEDs light, then the laptop shuts itself off. Unplug power cord from the laptop. Reinstall the memory modules. Make sure they are seated correctly. Put the battery back in, plug the laptop back in, and power on. Laptop should power on and boot up properly.
May need to hold the power button down to get it to power on properly.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Dec 03, 2011 | Dell Inspiron 6000 Notebook
I have a dell inspiron 6000 laptop When i press the start button the power lights stay on for about 5 seconds , then it switches off again. I dose not seam to engage the the operating system I would like...
Check that your power supply/AC adpater is plugged in and working. It could be that you are running on the battery only and if the battery is drained, it tries to start then shuts down again.
Feb 11, 2010 | Dell Inspiron 6000 Notebook
When the lap top logs off front light stays on
Do you still have the power cord plugged in? There are indicator light s for Battery operation, power on, hard drive activity. If you just logged off but the laptop is stillpowered on, then there will be a light indicating that. If you powered off the laptop but left it plugged into a wall outlet, then there is a chrging indicator that will stay lit.
Sep 11, 2009 | Dell Inspiron 6000 Notebook
Inspiron Battery Light Flashing Orange
Battery.
Dell has a chip internal to the battery programed to shut down after a certain number of charge cycles. This means every time you plug the laptop in with the battery installed. When it reaches this determined number the battery effectively shuts down, even though technically it's still good. There have been loads of complaints on the net toward Dell over this issue. I have myself experience this. Battery good one day, powered down, went home, powered up... only to receive the deadly flashing light. Only cure is to replace battery. Several hacks trying to get around this but they're all horrible. Bad Dell - bad, bad Dell!
Jun 29, 2009 | Dell Inspiron 6000 Notebook
Dell shut down automaticly can someone help
Sounds like the laptop is shutting down as a safety feature from overheating. Look to see if the fan is running underneath the laptop/notebook. It's possible that the fan is defective. If not, are you blocking the vents? Make sure this is room for air to circulate.
If it's not the overheating issue, do you have the power management system software set to hibernate? Maybe it is shutting down at the time interval set.
Hope this helps.
Dec 24, 2008 | Dell Inspiron 6000 Notebook
How to keep number lock on after comuter is shut down and restart
  1. Start the registery editer (regedit)
  2. Go to HKEY_CURRENT_USER \ Control Panel \ Keyboard \
  3. Double-click the value InitialKeyboardIndicators, and enter 2 as it's Value data
  4. Close the registry editor
  5. Log off, or restart Windows for the changes to take effect
Dec 16, 2008 | Dell Inspiron 6000 Notebook
Sudden shutdown dell inspiron 6000
hi, i have something strange found in my inspiron 6000:
it looses SMD-parts in the dc-power-converter!
...strange isn't it?
maybe are the suddenly shutdowns the beginning of this ****!
you need someone who knows good soldering....
...and maybe someone can tell me which kind of parts the mine d6000 has loosen :oD ?
it came back from dell *without*...!!!
...please can someone post me a foto?...
thanx, lapdoc
Dell Inspiron 6000 Notebook Logo
341 people viewed this question
Alun Cox
