Question about Crosley Arlington Stack-O-Matic CR66 Shelf System
Dryer run but wont get hot - Crosley Arlington Stack-O-Matic CR66 Shelf System
    President:
  • 942 Answers
Hi..
If your dryer not get hot check this
  • Check for proper air flow
If the flow of the air in your clothes dryer is impeded, the clothes will dry slowly or not at all. Also, a blockage in the vent system can be a fire hazard.
Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If you feel no air or the flow is weak, follow the steps below.
  • Test the safety fuse
  • Test the thermostats
The dryer uses multiple thermostats to regulate the temperature. When the temperature is higher than the preset limit of a particular thermostat, the thermostat breaks the circuit and the heater goes off. When the temperature cools enough, the thermostat closes the circuit again and the heat can come on.
  • Test the centrifugal switch
  • Test the timer motor
  • Test the heating element
Good luck !!!
Regards
PCmania
Posted on Jul 15, 2009
Wont heat on low heat only on high heat and keeps running
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 15, 2011 | Whirlpool Dryers
Dryer wont get hot ?
my dryer runs and everything but wont get hot
Jul 23, 2010 | GE Profile Harmony DPGT750EC Electric...
Dryer gets hot close wont dry cleaned vent as well
how long is the vent run,anything over 15 feet will slow drying process
Mar 18, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer wont get hot
check thermal fuse
Jan 21, 2010 | Maytag Dryers
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
Wont blow hot air
heating element failure 30 bucks and an hour of labor
Jan 14, 2009 | Dryers
Wont blow hot air
check that you have 240 volts to the dryer terminal block
if so check the element and the element thermastats
May 07, 2008 | Estate EED4300SQ Dryer
Crosley Arlington Stack-O-Matic CR66 Shelf System Logo
49 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
