Question about Kenmore 63942 Dryer
My electric wont heat up i have replaced heating element and thermostat and therm limter any sug
    President:
  • 1,723 Answers
Verify that there is 240 volts coning in from breaker. You still have a contact in the motor centrifugal switch you haven't checked too, thermal fuse and high temp limit thermostat.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 15, 2009
Dryer only heats for 10
I am sorry that you have had to replace so many components. Since you didn't leave a model number I have to answer generically. The symptoms you have would lead me to check out the thermal switch. If it is sensing a too hot condition it will cut the power to the heating element.
Jan 25, 2012 | Samsung Dryers
Fer211as heats but wont dry! heating element comes on but kicks off after gets to temp then element will not come back on unless stopped and restarted?
Runs but will not heat
1.loose wiring--check terminals & wiring
2. Defective thermostat--replace thermostat
3.defective centrifugal switch in motor--replace switch (check linkage to motor)
4. Defective timer--replace timer
5. Open heater element---replace heater element
6. Heat switch set to off----set switch for desired heat
Sep 22, 2011 | Frigidaire FER211A Electric Dryer
Kenmore dryer blows cold air. I replaced heat element still no luck? model 96263800
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The heating circuit is not just composed solely by the heating element, it is composed by the thermal cut-off, high-limit thermostat, cycling thermostat, motor centrifugal switch, and the timer. The first thing to look at when an electric dryer stops heating is the thermal cut-off. It cuts power to the heating element when it blows most likely due to the failure of the high-limit thermostat. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Kenmore Dryers
Dryer wont heat , heating element replaced
make sure you are getting full power to the heating element. if not check the thermostat at heater the one further back for continuity. it should beep or read "0" ohms. if not replace it.
Feb 09, 2011 | Amana NED7200TW Electric Dryer
Stopped drying replaced High limit switch on heating element and fuse/replaced therm on blower housing
Check 220v at wall and back of dryer. Must be across the line
220
It will run but not heat on 110. Check breaker
Check element for continuity
Jul 18, 2010 | Whirlpool LEQ9858P Electric Dryer
Fisher Paykel DEGX1 no heat, therm tripping - used multimeter
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
May 31, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My dryer wont heat up or shut down
It's not heating up because the heating element is broken and should be replaced. It won't shut down because the thermostat isn't sensing heat and continues to run while expecting heat. So replacing the heating element should get it running properly.
Mar 23, 2010 | Whirlpool LER5636P Electric Dryer
Oven wont heat to temp its displaying no codes,
Generally speaking, if an electric oven isn't reaching the correct temperature it's usually the element or the thermostat to blame. This tips should help you diagnose what's causing the problem:
If the bake element isn't heating at all or if when it's turned on it starts tripping breakers and blowing fuses than it's probably the element that needs to be replaced. Here's our guide to how to replace a fan oven element:
If the element is heating but the oven temperature isn't accurate for where it should be than it could be the thermostat. You can test these hypothesis out with certainity by testing the continuity of both the element & the thermostat.
You should also visually ***** to make sure that there isn't any loose wiring in your cooker.
Obviously before playing around with the cooker make sure that it's unplugged and drained of residual electricy.
Mar 10, 2010 | Kitchen Ranges
Neptune mdg3000aww starts heating and runs fine but stops heating shortly after start up can restart heater starts again and shuts down
If the machine keeps running but just not heating you have a thermostat issue. It could be the operating therm. or the high temp limit therm malfunctioning, shutting off the element.
If the machine stops running completely, check the door switch.
Jul 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Zanussi zbf 760 (9 yrs old now)
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances How to Video Tutorials on Domestic Appliances
Sep 24, 2007 | Zanussi ZBF360 Electric Single Oven
Kenmore 63942 Dryer Logo
93 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
