Good morning Linda, the noise you're hearing is probably the cooling fan with a bad bearing. That would be the only moving part that would make noise. It's a pain in the neck to get to but fairly easy to swap out. Definitely easier with two people. Or it could be a bad bearing on the convection fan motor. Set it to temp and then open the door once it starts to heat, That will cut power to convection fan and noise will stop.Hope that helps.
Is it a convectional oven? If so, this is the fan turning on to circulate the heat. Being an electric oven, there really shouldn't be any noise whats so ever when on. I suspect your have a convectional oven and the fan is making the noise...either because it is working fine...or because its not and needs to be replaced.
The fan is for air circulation regulation, e.g. preventing steam (and smoke) from building up inside, and also stops air pressure from building up inside so you won't get a blast of steam coming out or worse. On the convection side it heats the food faster and more evenly. You will need to replace the fan assembly to keep the microwave safe. the noise and sparks are probably due to spent bearings and / or a dislodged fan scraping against another surface or something getting in the way of the fan
If you can get at the fan blades without taking anything apart, try to turn the fan blade by using a small screwdriver or even a small wooden skewer. Listen to see if the blades are making contact with either fan cover or the back of the oven or the edges of the convection opening.
Once you determine which blade(s) are making contact, use a sharpie marker to mark those blades you need to correct. That way if the blades are hitting the fan cover, you'll know which ones need to be bent back into shape once the cover is removed.
With the oven turned off, you should be able to remove the circulating fan cover and correctly bend the fan blades back into shape and stop the noise.
Hope you found this very helpful and best regards!
I had the same problem. The screen protecting the fan bends into the fan from the heat. Take off the top front control panel (3 screws), reach in to the back where the fan is and push the screen back away from the fan. As always, turn the power off first to avoid shock. This should solve your noise problem.
