Question about Samsung LE32R41BD 32 in. HD-Ready LCD Television
Samsung LCD TV LE26R7
White line across tv
Re: Samsung LCD TV LE26R7 - Samsung LE32R41BD 32 in. HD-Ready LCD Television Flat Panel Televisions
No sound via pc
Posted on Mar 31, 2008
0 characters
3 Points
White line across screen
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sony 46 KDL46EX523 LCD TV
I have a Samsung LN46A650 LCD TV and recently I started getting a white line across the top of the screen. Sometimes the white line is thicker on the left side of the screen. Sometimes after the white...
Yes, it's the t-con board, a well know problem in this tv. Here it is
Sep 13, 2011 | Samsung LN46A650 46 in. LCD HDTV
Our LN40A630 has three horizontal white lines across the screen on power up (center, center of upper half , and center of lower half). After about five minutes the lines go away. Tried Picture Test in...
This is a sign of your LCD panel beginning to die. Sometime soon those lines won't fade away and will become permanent parts of your TV screen.
Considering the fact that your TV is approx 3-4 years old, this is normally the expected lifespan of a TV. Once the TV becomes unwatchable, your best bet would be to begin shopping for a new one.
Mar 07, 2011 | Samsung LN40A630 40 in. LCD TV
Lines down screen
We have a Samsung LE32A457, whilst we were watching T.V tonight the top halve of the screen suddenly appeared with green lines halfway down the screen and that half of the picture was unwatchable, T.V is 2 years old. We have removed all scart leads but this did not help and the problem still exists, when shutting down a white horizontal line across the centre of the screen appears from this line upwards the picture is faulty. Any help or advice would be grateful.
Jul 08, 2010 | Samsung LE32A457 32 in. LCD TV
Samsung LNT4061F LCD tv with red specs and white lines on screen
Yes this is the color wheel that this tv has you would need to remplace the color wheel here is a web site where you can find it for a good price
Good Luck and besta regards
Dec 18, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Icannot access dmenu on the remote. samsung le26r7
my samsung le32 tv is stuck on BBC 1 Mono. i cannot access the D menu or change on to any DTV channels. I am in an area that broadcasts in digital. the tv works ok if I connect a freeview box
Oct 01, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Sharp Aquos LC-32D41U
The unit has bad drive ic's,which is part of the lcd panel.It is not cheap to fix.
Feb 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
White horizontal flickering lines
If still under warranty, take it back. but first check your cable input connections or cable signal may have went bad. Lastly it could be the signal module inside.
Jan 02, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
Samsung LE32R41BD 32 in. HD-Ready LCD Television Logo
360 people viewed this question
Top Samsung Flat Panel Televisions Experts
xxxxxx xxx
Steve McIntosh
Level 1 Expert
Steven Wander
Steven Wander
Are you a Samsung Flat Panel Television Expert? Answer questions, earn points and help others
