Question about HP (ZD929AA) Computer Speakers
Re-connecting speakers I just moved and am trying to re-connect my speakers but am not sure if I connect them to the PC or to the monitor.
  • tina1962 Dec 01, 2007
    my speakers is just making noise. But no music
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Good Morning Skugurl
Try to remember how you put the cables,
but as a rule, put in the green and black , cables are sometimes set with this colors. see if not in mute on control panel, sound setting. or in the little speaker beside the clock.
test the sound with any CD Music?
Carl
Posted on Nov 18, 2007
Where do I connect the speakers to the monitor. I have a Flatron L1922P monitor. I ordered 2.0 USB Multimedia speakers that come with a 3.5mm stereo plug and USB plug. I must not being doing something...
Your speakers do not plug into your monitor. Your speakers should be connected to a USB slot on your PC tower and the 3.5mm stereo plug should be put into the green stereo jack on your PC tower. If your audio jacks on your PC are not colour coded, then you should look for the jack which has a picture of a set of earphones over them.
Depending on your speakers, you may or may not be required to keep the stereo plug connected in order to get sound. Some models transmit model over the USB connection and others just use the USB connection as a way to supply power to the speakers and need the stereo plug to be connected in order to have sound. I suggest trying both.
Mar 25, 2011 | LG L1922P 19" LCD Monitor
I had sound on my computer, then it was moved to a new desk (same pc, same monitor). I no longer have sound. How do I hook it up to get sound back
Check the speaker connections. if speakers in monitor make sure usb cable is connected to monitor and computer.
Mar 08, 2011 | ViewSonic VA721 17" LCD Monitor
Have many bran new hp La1905wg compac monitors with computers. Have powered up and get no signal then monitor says going to sleep. All do the same regardless of what monitor cable is used. What is...
Hello there,
Step 1:
Check all connections make sure everything is connected correctly .
The monitor should have two cords one for power and one VGA to the PC make sure both are connected correctly.
Step 2:
check the input on the Monitor make sure you are on the correct input for the type of Cord you are using.
Step 3:
If you are still not able to get a Picture try using the Monitor on a different PC it may be a bad Monitor, if you move the monitor to a different PC and it works then its the Graphics Card in that PC that is not working .
if you move the monitor to a different PC and it doesn't work then its the Monitor.
Thank you don't forget to Rate
Jan 25, 2011 | Computers & Internet
I have no sound from my monitor speakers
Chances are you need to connect your monitor speakers by way of a USB cable. Look for a USB port on the monitor, connect it up and run the software that came with the PC to install the software to direct your sound to the monitor speakers.
Aug 21, 2009 | Hannspree HANNS-G 19" Widescreen Monitor
Need help getting audio to play on my HP 2009m monitor which is connected to my HP laptop.
The speakers on the monitor will work only when the sound output from the laptop is connected to the monitor speakers. Please make sure that you connect the cable from "Audio OUT" (generally Green colored port where you connect your headphone or external speakers) on the Laptop to the "Audio IN" port on the monitor.
Please let me know if it works.
Thanks and Regards,
Srinivas
Apr 21, 2009 | Computers & Internet
Have in built sound card in D845HV mother board. Experiencing heavy distortion as soon as the mic is connected. It was working well till last month.
Distorted or scratchy sound can be caused by several problems. Improving the sound can be as simple as rearranging your hardware components. The following suggestions may resolve the problem of scratchy sound:
  • Are there any other devices around the speakers or wires for the speakers? Electro-magnetic interference can cause poor audio. Try moving your speakers and wires around and away from other devices.
  • Have you recently added any new cards to your computer? Cards within the computer can also cause electro-magnetic interference. Try moving the card to another location within the computer, if possible.
  • Verify that you are not encountering a hardware issue with the speakers you have by trying another pair of computer speakers.
  • Poor audio quality or low volumes may occur if you are using passive (non-amplified) speakers.
  • Are your speakers too close to your monitor? The speakers can pick up electrical noise from your monitor so move them farther away. Subwoofers should never be placed near the monitor because their powerful magnets can interfere with the picture. They should be on the floor to maximize low-frequency transmission.
  • Are you experiencing sound problems only with particular games or programs? If you notice sound problems such as stuttering voices and static on some games or programs but not others, check with the software vendor for a software patch.
Data courtesy of: http://www.intel.com/support/motherboards/desktop/sb/CS-020642.htm
Also make sure to inspect your microphone, and the cord that connects it to your PC, for physical damage.
If you're still experiencing issues, you may need to replace the your microphone.
I hope this helps.
Ben P.
Apr 11, 2009 | Computers & Internet
Lost manual for hp compact.
The speakers wires are normally color coded if the computer isn't ancient, the Speaker PLUG is green, if you are using the speakers in the monitor, then plug the green one from monitor to green jack on back of PC, (Microphone plug and jack is pink/Red).
If you are using other speakers 3rd party, 4.1,5.1, the hookup is different usually, But I think you need green to green, there should only be one green plug on back of PC, It may be labled sound out. but yours is probably green.
PS you also need to kake sure the monitor speakers dont require their own Power Supply/ AC adapter, Most of them do, while some desktop and monitor speakers do not just connect the cord ffrom monitor to green jack, "sound out". If this helps, thanks for the feedback
Mar 31, 2009 | HP Pavilion F1703 17" LCD Monitor
Connecting speakers to compacq computer
its a green round plug on the back of the pc
May 02, 2008 | Audio Players & Recorders
Speakers
Start with the obvious! Are all connections to PC connected? Be sure that the proper wires are connected to the proper plug in.
Next you may have to adjust the volume control thru Windows. Look for the small speaker icon at the bottom right (usually) of the screen. Double click, and be sure that all of the volume controls are "up" and be sure that none of them are "muted"
There also may be a volume control on the monitor, speaker assembly.
Dec 31, 2007 | HP vs15 15"LCD Flat Panel Monitor
Spreaker
try connecting the speaker wire to the green jack on the back of the computer
Nov 13, 2007 | BenQ FP751 (White) 17" LCD Monitor
HP (ZD929AA) Computer Speakers Logo
44 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
