Question about Nintendo DS Lite Console
Dropped in water, dried it out light on sholuder comes on but nothing else happens then it switches off
  • 51 Answers
Buy a new one; something probably rusted.
Posted on Jul 19, 2009
Wf310 wont start lights are on but when wash lights up nothing happensWf310 wont start lights are on but when wash lights up nothing happens
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
start with the door switch as if this is faulty the program controller will not work.If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Jul 02, 2011 | Hotpoint Washing Machines
Yesterday i accidentally dropped my Blackberry Curve 8520 into water , i took the battery out to dry , i dried all of my phone . but after i put the battery back in, once it was fully dry, the phone turned...
this is happening because water has not 1005 dried off the phone. There is still an atom of water in the phone.
There is nothing to worry about, all you need to do is to give the phone sometime and it will respond perfectly again.
While the phone is on, the heat the phone produces when it on will dry the water completely sooner or later.
So there is nothing to worry about, just give some time....
Good luck.
Feb 17, 2011 | RIM BlackBerry Curve 8520 Smartphone
Opperating an hinari refresh air pac9100c/fc air conditioning unit
Hi I have the Henari Refesh Air 3-in-1 and am having problems get the Dehumidifier only to work. I've done as above. There is a little pipe inside next to the water collector. This is inside. when i put the water collector tray in the machine switches off. I have switched it off and on and set it to dry but nothing is happening. If i take the water collector out then it switches on and u must unstop the pipe and ly it in a bucket. the machine then switches on and runs but the "water full" light then comes on and after running it for about half hour nothing seems to happen? Can you please help. I have a serious humid problem in my house.
Nov 25, 2010 | Heating & Cooling
I dropped it in water and after that nothing is happening on it no light no on and off nothing it looks dead to me
Switch off the phone. Take out the battery and place the phone and the battery in the sun for few hours so that it is completely dried. Replace the battery and the switch on the phone. If it starts you are a lucky person. If it does not then you have to go for a new phone. Generally once the water gets into phone it renders it useless.
Apr 14, 2010 | Motorola Mobility RAZR V3
Stainless Steel- LitchenAid diswasher will not star
This doe seem that the anti flood system has triggered. This device puts the machiene in pump out mode and shuts off the input water supply.
The device is a safety device that triggers once it detects a water leak (pipe / clamp) and consists of a polystireene float and micro switch at the floor of the washer. First check to see if the float has activated the micro switch and then dry the machiene floor and check for leaks.
Jan 25, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Maytag Neptune MDG4000BWW
check your door switch it might be broken. push the door switch in with your hand. does the light turn off? if no this is your problem
Aug 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Zanussi Dishwasher Model no DE6744 Not working
HI. After me fiddling about with the machine,checkingto make sure water was available to it and trying to locate the float switch (whicu i didnt) .
Then i left it standing overnight aqnd the believe it or not it worked in the morning.
I let it run through the cycles of a program which it did ok.
Hoping it carries on ok. Kenethyorky
Aug 11, 2008 | Dishwashers
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Nintendo DS Lite Console Logo
52 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
