PT-47WXC43G green convergence no longer in alignment...
...and can no longer be adjusted. This randomly happened when I turned on the TV this morning after 3 years of use. The picture now looks 3D and is not watchable. Here is a picture...
http://i29.tinypic.com/2aikj0w.jpg
Is this repairable?
1.What parts do I need?
2.Guide to open the front of the TV?
3.Guide to install repair parts?
-Thanks!
  • themastersur
    themastersur Jul 16, 2009
    Can anyone confirm this is the best solution and not just a guy trying to get me to buy his expensive $50 repair kits. Other threads suggested a different site where you buy ICs that are only $20.
  • 8,617 Answers
You can get the following repair kit at the following link. which contains the parts and the CD which has the instructions on how to do the repair. The kit you need is called the PT-53WX53G, PT-56WX53G, PT-
47WX53G, PT-47wx33G, PT-47WXC43G
and PT4743G. Convergence repair kit its at the following link.
http://www.tvrepairworld.com/
Posted on Jul 15, 2009
I have a Panasonic PT-47WX53, this morning when i went to turn the TV on the picture was not align. The red and blue look aligned but not the green, i opened the back and when I coved the green light the...
This kind of problem occurs due to failure of convergence output chips located on main circuit board of tv and replacement of convergence output chips will hopefully solve your tv problem.
Soldering work is involve to replace these two chips so have local tv repairman for that job if you are not familiar doing so.
Thanks.
Jun 29, 2011 | Panasonic PT-47WX53 47" Rear Projection...
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
When i try to adjust the convergence, the red and blue adjust ok, i assume the green in the basline color, but it turns up on the right side of the screen and the picture has a green wave in the lower left...
The tv 100% have convergence problems,it dead,if have any colors lines mis alignment or don't stay in the convergence - + grid.The tv convergence board is dead.The 2 STK convergence ICS and some or all is resitors are dead.Must replaced these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 11, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WXC43G green ONLY is bowed on bottom and top
It still convergence chip problem, check big resistors nearby these chips that would be open or devalued and causing problem, specially in green convergence area, your green tube/ gun is just fine and just not getting convergence output signal to show correct image.
I would suggest to download service manual copy of this tv for small fee from any website and fix the issue with schematics help.
Thanks.
May 02, 2010 | Panasonic PT-47WXC43 47" Rear Projection...
Hi. My Sony Videoscope XBR's Convergence Allignment
I happen to share this same problem. The alignment of the gridlines on the standard convergence panel are completely abnormal, and if I attempt to auto-adjust the TV, it flashes different colors on the sides of the screen , and then turns off the convergence settings.
Feb 01, 2010 | Sony Televison & Video
Blue Convergence out of sync
you need to adjust the convergence. you set up convergence 1 then 2. follow the manual. (Its easy, you just align the + signs so they make one white one (instead of three green, red, blue) sounds like something or someone bumped the tv, causing the blue lens to shift a little.
Nov 23, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Red and Blue slightly out of alignment
If constant all over the screen it is the static convergence that needs adjusting.
The green is not adjustable!
Move the red magnets with the blue covered with a piece of card to align with the green and then move the blue with the red covered to align with the green.
May 13, 2017 | Panasonic PT-51G41 51 in. Rear Projection...
Panasonic PT -47WXC43G 42 inch TV
replace the convergence amp ICs both of them. They cost about 15.00 each
Mar 09, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Pt 53wx53 convergence
Same here,sorry I can ajust all but it just wont come in perfect.
What is the problem.Will the sevice menu work?
how do you get it?
Dec 16, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Cannot adjust convergence, screen has rainbow effect
You probably need to change out the semiconductors. The parts are STK392-110. There are two of them, one for horizontal and one for vertical. Search it online more.
Dec 28, 2006 | Panasonic PT-53WX53 53" Rear Projection...
Televison & Video Logo
555 people viewed this question
Top Televison & Video Experts
