Singer 2250 Tradition Logo
A
Anonymous Posted on Jan 18, 2016
How to fix a pressure foot lifter on a singer tradition
matty_w
Level 2:
Legend:
An expert who has written 200 answers of more than 400 characters.
  • Singer Expert 631 Answers
  • Posted on Jan 02, 2017
matty_w
Singer Expert
Level 2:
Legend:
Answers
631
Questions
0
Helped
182803
Points
809
You can get a replacement Lifter from Sewing Parts Online here:
http://www.sewingpartsonline.com/presser-bar-lifter-singer-v880153000.aspx
Most likely, the screw end on the machine has broken off.
4 Related Answers
Anonymous
  • Posted on Jan 03, 2010
SOURCE: The presser foot lifter of my Singer 9432 has disconnected
Had the same problem.
Open the cover where the light bulb is.
Follow the presser foot rod up into the machine.
You will find a metal keeper with a set screw facing the now open end of the machine.
That set screw has most likely come loose.
Since the presser foot is spring loaded to the down position leave the presser foot raising lever in the down position.
With your flat bladed screwdriver, gently push the metal keeper to it's lowest position. If it does not go easy, loosen the metal keeper set screw a bit. Lefty loosey.
Tighten the set screw on the metal keeper. Righty tighty.
bogo_7
Fara Wright
  • Posted on Apr 14, 2014
SOURCE: Singer SM MN 93234--pressure foot lifter won't stay lifted, falls down. What to do?
sorry can't help you there may be you need it check by a sewing machine mechanic may be a screw is lose and need to be tight.
Ruth summersides
  • 1493 Answers
  • Posted on Dec 28, 2014
SOURCE: how to adjust pressure foot on singer model 14s654
Unscrew pressure foot and replace or use finer needles, and make sure they are not bent or that the zig zag is engaged
wind_dancer
Betty Vincent
  • Posted on Jul 04, 2015
SOURCE: on my singer 9005 the
When I push the pedal nothing happens. I can hear the machine trying to sew, but nothing happens.
Singer 7033, presser foot is disconnected. How do I fix it?
If the presser foot isn't connected to the presser foot shank, place the foot under the center of the shank. Lower the presser foot lifter making sure that the shank goes over the presser foot pin. Press down firmly on the screw that holds the presser foot shank until you hear the foot snap into the shank. Do not turn the presser foot shank screw. See the pictures on page 9 of the manual (page 11 of the PDF). Manuals LIb has this page here https://www.manualslib.com/manual/470415/Singer-7033.html?page=11#manual . The manual is also available from Singer on their support page: https://www.singer.com/support . The direct link to the manual is https://www.singer.com/sites/default/files/product_manual/SINGER%207029_7033_%207035%20and%209410%20Sewing%20Machine.pdf . For feet that are attached to the slant shank, you loosen the presser foot shank screw. Place the shank over the presser foot screw and then tighten the screw to hold the presser foot. If you removed a foot and the shank together, put it back on. Make sure that the needle and the presser foot lifter are in their highest positions. Push up the front side (toe) of the presser foot until the foot snaps off the shank.
If the presser foot doesn't snap into place, make sure that you have everything aligned properly. Otherwise check for damage to the presser foot and the shank. Replace any damaged parts. Some presser feet are available here: https://www.sewingpartsonline.com/singer-7033-sewing-machine-parts.aspx .
I hope this helps.
Repairing a Singer Sewing machine presser foot lifter.
Inside the foot the wires are connected to two different screws. They are obviously coming loose by being pulled.
1. Open the foot on the bottom.
2. Look where the screws are. You need to have the wires connected there.
3. Before connecting to screws: tie a knot in the wire from the inside of the foot pedal where the wire protrudes through the hole.
4. Now, tightly connect the wire to each screw. Apply bottom of bracket. Now, sew!!!!!!!!!!
1helpful
Singer 9015
Sounds like the linkage between the lifter and foot is caput. If you open the case, you void the warranty.
Apr 14, 2014 • Singer 7422
The presser foot lifter on my machine is not engaging this allows the needle assembly to spin - is there a way to fix this?
Your question is not clear. The pressure foot lifter only lifts the pressure foot. It doesn't make the needle spin.
17helpful
2answers
Faulty presser foot lifter on a singer 2110/2112.
I have seen these machines with broken presser bar clamps (something inside the head). If it is just a bind then some oil on the presser bar may work, if the clamp is broken then it is probably not worth fixing.
2answers
On my singer 9005 the pressure foot lifter does not stay in the up position - does not hold the pressure foot up.
These plastic presser bar lifters do wear out a lot ,very common,,,,,,,,You can lift it up and file as close to the machine side on top just a couple of stroke son the file will usually give it a surface to hang on and it will stay up ,much easier than changing the plastic lever
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
