Question about Epson STYLUS R230 InkJet Photo Printer
Printing problem my epson r230 prints dual image on cd tray
Printer does not print with red light
Posted on Oct 06, 2009
Virtually refuses to print CD's. Have re-whitened the blocks on the CD tray and still refuses, just "jams" every time
You will need to check the rollers insiode the printer and the full printer path, cd paper is thicker than standard paper and will take less to block it, also look for stickyness on the print rollers
May 10, 2011 | Epson STYLUS R230 InkJet Photo Printer
How do i print on a CD?
sorry to inform but you dont print on CD.
You print on paper and then paste it on CD :-)
That's called "label" printing.
Feb 13, 2011 | Epson STYLUS R230 InkJet Photo Printer
My new epson r230x printer is printing text and images blur
pls download the latest drivers software version of the printer that you use... then after that reinstall the old drivers software that you install previously.
Mar 02, 2010 | Epson STYLUS R230 InkJet Photo Printer
Printing is really slow almost 10 mins to print i am using Vista and have had updated the driver for vista but still
Epson R230 print slow at PHOTO, very slow at BEST PHOTO, if you do not need photo quality prints try printng at TEXT AND IMAGE for faster printing and the quality is still good. Also try to lower the resolution of that you are about to print, high the resoluton images takes longer time to print. Hope this will help you, Good luck!
Oct 14, 2009 | Epson STYLUS R230 InkJet Photo Printer
Red light on steady
If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
Can not print on to cds
I have R265 ... make sure the tray is set up in the corner and aligned properly. and check if perhaps there's a corner of the tray missing due to an accidental damage or something and the lases senses it's not there, which causes the printer to think it's not aligned right
Nov 13, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson r230
hello babu,
the problem is not with the printer, problem is with your general knowledge, to print on cd/dvd surface means you have to stick the sticker (cd label sticker) on the cd, then put the cd on the printer to print.
ok
bye bye
hope u will soon understand......
Jun 22, 2008 | Epson Stylus Photo R220 InkJet Printer
Image print on disc
Lightsribe disc is only monotone colour mostly its gold color.
So if you want to print an image on it.
Probably you will not like it.
Instead buy an Epson R230 or newer series. Because it has CD printer.
It can print beautiful colors you want.
Buy also printable CD. It can be generic CD or branded like Verbatim, Sony, TDK, Melody.
Buy a printable CD with a paper texture on the top.
If not it might smudge the ink on the top.
Its messy.
Well then. I hope this help
Jun 15, 2008 | Computers & Internet
Epson STYLUS R230 InkJet Photo Printer Logo
75 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
