Complete 2006 Mitsubishi Lancer Evolution IX Evo 9 Workshop Repair Service... Just follow the link and download the repair manual. All your queries will be solved
SOURCE: location of fuel filter for 2005 Mitsubishi Lancer 1.8 litre
a guess... fuel filter should be up against subframe behind rear wheel in front of fuel tank...follow fuel lines down frame rail from motor to back end to find it.... good luck
SOURCE: 2006 mitsubishi lancer evo ix clutch
there are special tools needed that only dealers and some trans shops will have.Definitely a no-no for back yard mechanic
SOURCE: Hi i have a mitsubishi lancer 1.3 petrol 2006, i
wow ok i am from australia our lancers only come in a 2.0 or 2.4 i was shocked to see a 1.3 lancer
now with the key
every time you incert the key into the ignition it reads the key as there is a chip in the orignal keys so thatway the immobiliser knows thatit is safe for the car to start
if the cra can not read the key it will not let the car start evan if it is twisting to start etc
you need to go to mitsubishi and have them copy some new keys and let them reset the codes on the immobiliser if you try to do so your self it may trigger a cold shut down
this is when the immobiliser its self needs to be replaces as well as the keys
hopes this helps
ricko
SOURCE: location of flasher unit on 2006 Vue
the flasher for the turn and 4 ways is in the 4 way switch,its internal,,,,
SOURCE: where is the flasher located in a 2006 impala
under the dash...driver side close to fuse box(behind)
