Question about Raynox Video Micro (VM3000)
Power come from switch but it will not spin. - Raynox Video Micro (VM3000)
    President:
  • 1,129 Answers
Start up capacitor may be shot or the motor.
Posted on Jul 15, 2009
Karcher t50 t-racer not spinning
Check power to start switch and relay switch to motor.
Oct 22, 2012 | Karcher Garden
GWL11 won't start at all.
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Oct 08, 2008 | Fisher and Paykel GWL11 Top Load Washer
Hi, my Samsung Washing Machine does not want to spin after it has done the rinse cycle, it gives me a dE error code. Please help?
The De code is a door switch error. The door switch is broken or a wire to the door switch is loose or broke. The door.. should be closed while your machine is in spinning mode, thats a safety feature so nobody gets hurt while spinning, if you open door the spinning should stop.
Check your switch by ohming it with a voltmeter http://www.ehow.com/how_5371933_test-switch-ohm-meter.html
If its not the switch, then its a wiring problem..Makes sure the wiring has a power source, by connecting the wires in series with a voltmeter ..
Mar 10, 2011 | Dishwashers
My Dryer has power, spins the drum, but only air
Well I know that older dryers came with a wiring schematic for where all the wires go, but yours may not. There is a lot of experimenting with dryers when it comes to diagnosing. I would say that it is very possible a door switch could cause that depending the position its stuck in. If no power is going through that switch then the heating elements may work off of whether that switch switch is operating or not. If your heating elements worked before this then I would have no doubt that they are working now. If the switch being replaced doesn't work I would then go and check for full voltage at your main terminals (120V per power wire and 240V across both of the wires)
May 10, 2010 | Kenmore 62722 Electric Dryer
My Maytag washer agitates, and will pump during the spin cycle but will not spin
Check the lid switch is operating. It will not spin for safety reasons if it thinks the door is open.
If the switch is good test for power at the wigwag (spin) solenoid when in spin cycle. Since it agitates the solenoid itself could be bad.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Aug 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Dyson DC 24 pick up head wont spin
- Look for the reset button on the side of the brushbar housing - there should be a red sticker and a red button. Push it once. It's
not gonna stay depressed, it's gonna pop right out - that's normal.
- Step on the red pedal on the back
- Turn the machine on with the red power button
- Press the gray button next to the red power button - this is the ON/OFF switch for the brushbar - if it doesn't spin, press and hold the gray button down for 10 seconds
- If it still isn't spinning, remove the brushbar and make sure nothing is blocking it and withholding it from spinning
- For further troubleshooting assistance call the Dyson helpline, they know what they're doing
Jun 20, 2009 | Dyson Ball DC24 Bagless Upright Vacuum
Possible lid switch stopping basket from spinning
Lid switch is safety mechanism that cuts off power to motor when lid is open. If it is broken or faulty you will not get power to motor during spin. Hope this helps!
May 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Waterpump won't pump and spin cycle won't start.
one of 2 things are happpening iether hte timer is not sending down the power to operate the pump , or switch is not closing correctly to allow power to the pump
Mar 19, 2008 | Frigidaire FWS833A Top Load Washer
Raynox Video Micro (VM3000) Logo
24 people viewed this question
Top Raynox Cameras Experts
Are you a Raynox Camera Expert? Answer questions, earn points and help others
