Question about Panasonic Televison & Video
I need 3 digit code for a panasonic TH-37PX80B T/V to enable me to set remote control on bt vision
SOURCE: panasonic code
The code is 0051
on your sky remote press the TV button then
the select and Red button at the same time , hold until the led on the remote blnks twice
then press TV and enter code 0051 then press select and the remote will blink twice again to acknowledge the code
if you still have your Sky box manual all these details are in there also
im a sky engineer by the way , goodluck
Posted on May 05, 2009
SOURCE: LG 42LC2S - Remote control code
After many months trying to find the BT Vision code for my LG 32LC2D, i have just had success with 005 remembering to enter an additional zero after the remote has flashed three times, so you enter 0005.
Hope it works, good luck!
Posted on Jul 06, 2008
SkyGuy08
  • 27 Answers
SOURCE: remote control code
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Panasonic Code: 0051
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Posted on Apr 08, 2009
SOURCE: trying to find comcast digital code to use their
10250
Posted on Jun 16, 2009
4 digit TV code to set up to BT youview
You might need to reset the remote control if the codes don't work.
If you've got the BT YouView remote that came with the box (with the 'BT Vision' button on it), hold down the two buttons either side of '0', whilst also holding down the power button for around 5 seconds. The blue light on the remote should flash three times to confirm it's successfully reset.
If you've got the retail YouView remote (with the 'TV' and 'PVR' buttons on it), press and hold the 'TV' button and the red coloured button at the same time for 5 seconds. The 'TV' and 'PVR' buttons should flash red 3 times to confirm.
Try your codes again after. I believe 4483 is the code in the setup guide.
May 28, 2015 | Televison & Video
Need a code for my bt vision remote control? I have a panasonic tv.
0075 0099 0101 0104. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 20, 2014 | Televison & Video
Technika codes please for 40'' screen
Consult the owner manual (or Google the model of it for manual) but not all remotes will program for all sets and even if do will not have all the needed or wanted features the original remote has.
Nov 08, 2012 | Hitachi Televison & Video
I have an e-motion tv and am unable to set my bt vision controler up as can't find a code
Same problem solved through patient "trial & error" ... for my e-motion TV, the BT Vision remote works with code "0081"
To program the BT Vision remote, instructions can be found at:
http://bt.custhelp.com/app/answers/detail/a_id/13573/~/programming-my-black-bt-vision-remote-control
Mar 06, 2012 | Televison & Video
I need a remote control code to match my BT Vision remote control to a Panasonic TX-32LXD1 television please. Thanks, Andrew Straughan
Hi, Andrew! Does your remote control have a "code search" mode? Panasonic products are mandatory for all of universal remotes. but, new flat panels are, usually in a special section of your code manual, if you still have it. If not, try to start aut code search procedure and be patient: it might take 10-15 minutes till your set will start to respone. make sure, enter the code to memory, as soon as you see the set took the code. Otherwise? You must start all over.
Jan 23, 2010 | Panasonic TX-32LXD1 32 in. LCD Television
Panasonic VIERA TH-37PX80B 42" plasma telly
What ever sounds the best to you!. If you have a particular question regarding sound, let me know?
Jun 24, 2009 | Panasonic VIERA TH-37PX80B 37 in. Plasma...
Bt vision remote
www.remotecodelist.com .....................................T.
Mar 20, 2008 | Televison & Video
Remote control
the code for the bt.vision box remote to work a durabrand tv is under the emerson range the code i used was 004 it works fine
Oct 10, 2007 | Durabrand DU1901 TV
Televison & Video Logo
166 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
