Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Not getting cold
The fan is running, i also cleaned out the back. it is not geting cold neither side.
  • 744 Answers
Hi..
1)check your cutoff sensor, it is most likely a rod that will push up when the ice bin gets full, make sure its not stuck in the up position...
2) If the tube to the ice maker was not clogged with ice itself that is not your problem. The ice maker is thermally proctected and will not make ice unless the freezer is actually at zero degrees F. Not just frozen. The plastics in a freezer will be soft when warm even easily melt, but be hard when at operating temps. Just try setting your freezer colder to see if it kicks in. Give it at least 24 hrs. Don't do the human nature thing and open it every hour to see if it makes ice. You will just dump the cold air out. Listen for the ice to dump into the tray. I hope this helps..
thank u
rate me!!
Posted on Jul 15, 2009
13 yr old frigidaire refrigerator has stopped geting cold in freezer and refrigerator
how about the compressor motor still running?.then check the thermostat knob which set to off or get bad.
Oct 10, 2012 | Frigidaire 20.6 cu. ft. Top Freezer...
Both sides are not geting cold the compressor is working and the fan,what cloud be the problem
hello
The problem may be just a dirty condesor. It is located under the frig. clean all the dirt and dust out and you should be fine. I hope this helps. Please leave feedback.
Thanks
Aug 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My compressor stoped working and it got hot and
If the fan was the problem and the compressor is now running , it should start getting cold.
Oct 16, 2009 | Amana ARB2217C Bottom Freezer Refrigerator
Side by side refridge was dirty and I cleaned
I would pull the refrig out , and remove the back panel , covering the compressor and fan motor . Check to see if the fan is working . Fan not working , causes the divider panel , to get very hot . Also , fan not working , causes the compressor to over heat and cut off on the overload .
Sep 29, 2009 | GE Refrigerators
Freezer cold /refrigator warm . we have a side by side unit a couple of years old the freezer seems to work fine but the refrigator is warm .It don,t seem to make any funny noises and the back is clean
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
Jul 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag side by side not getting cold enough
look in the back should have a fan in the bottom probably very dusty if it is it cant cool fridge clean it and it should work unplug it to clean
Jun 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
Whirlpool side by side freezer not working fridge is fine
Pull out the fridge and unplug. Remove the back cover. Clean the condenser coils and fan. If they're difficult to get to, use compressed air to blow out. (you can get a can from walmart). That should fix the problem. If that doesn't work, then write back.
Doug
Jan 05, 2009 | Whirlpool GC5SHEXNS Side by Side...
Help refridgerator has no cold air
If fan under freezer is not running and or the compressor? That will be clue to helping you resolve this. Let me know.
Jan 03, 2009 | Jenn-Air JCD2295HES Side by Side...
Fridge no t geting cold
hi thanks for the question you may have a no defrost problem or the fan in freezer not running open freezer door you should be able to hear the fan if you hear the fan ok then reach in to the freezer to the back wall if you feel frost you have a no defrost problem thanks the appliance doc
Sep 04, 2008 | Jenn-Air JCD2389G Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
138 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
