Question about Intex Plunger Valve & Straniner Basket set for 18' or larger pool set & Model# 51, 635, 633, 520R Filter Pump
Pool pump intex 51 pumps water but return flow is low
I have a Intex pool pump model # 51, it pumps water but the return flow is very low to none, the cartridge is clean
  • Anonymous Mar 17, 2014
    I just bought a replacement pump for the pool (original 530 gph pump failed for second time). New pump is 2,500 gph. The return port is sucking in water at the top of the port while discharging water through the rest of the port, making a mini-whirlpool. The water level is just above the port. I ckecked for leaks in the piping and found none. Had to use an adaptor kit as pump hoses are larger than original hoses and ports for the pool. The adaptor utilizes a rubber gasket and threaded ring to clamp down on the port stub. I can't figure out why the rreturn port would be sucking in water at the same time that it is discharging water. The sucking noise is annoying after a short time and I am concerned about debris getting sucked into the return side of the pump as well as the suction port.
    Thanks
  • 297 Answers
If you cartridge is completly clean then start by disconecting the out tube that goes to the pump housing
sometimes debris gets caught there entering your pump.
a little hair causes other things to back up
once you are satisfird that those 2 things are ready then close it all up and open the bleeder cap on top of the cartridge holder
Now let water in from the suction side
when water starts coming out of the bleeder cap then open the return side
Now turn on the puimp
let it run for 20 seconds and then close your bleeder
Should be working fine after that.
dont forget to leave the bleeder cap alone on the bottom of the canister unless you are draining the water from the canister to clean it. As soon as you are done close it back up
Posted on Jul 15, 2009
After modifying our 20x 48 Summer Escapes pool to utilize our Intex Saltwater system - why is the saltwater pump showing low flow?
Index salt chlorinators need a certain flow rate. Check the flow rate on your pump to see if it is strong enough.
Mar 27, 2017 | Intex Pool & Spa
Water flow problems with Intex sand filter for above ground pool
if by flow problems are you saying excess air is being discharged back to pool out return hose ? if so this is a common thing on filters that go older than two or three seasons , the areation fingers inside filter housing are bad
Jun 16, 2012 | INTEX Sand Filter Pump
Can i use a sand filter with the intex krystal clear saltwater system?
Yes you can.
The saltwater chlorinator is connect to the outlet water pipe from the sand filter before the water returns to the pool.
Depending upon the model of the saltwater chlorinator It may need to be mounted horizontally or vertically, check with the installation instructions..
Apr 11, 2012 | Pool & Spa
What is the recommended end-of-season maintenance for the chlorinating pump?
According to the Intex website, the following maintenance is required for this product:
The Intex Saltwater Pool Systems are designed to operate with a minimum amount of maintenance. It is recommended to always turn the pump on prior to turning on the Saltwater Pool System (see Owner's Manual) unless the chlorine generator is part of a combination pool and filter set, to ensure that air pockets are eliminated from the hoses, and that water is flowing through the unit. In addition, the electrolytic cell should be examined and cleaned if necessary. The frequency of cleaning will depend on the local water conditions, pool usage conditions, and length of time the Saltwater Pool System is operated each day. (See Owner's Manual.)
The Intex Saltwater Pool Systems contain several features that minimize maintenance requirements:
1.) An automatic self-cleaning cycle: The Saltwater Pool System automatically undergoes a self-cleaning cycle to maximize the operating length of the electrolytic cell.
2.) Safety diagnostics: the Saltwater Pool System will alert the operator to three conditions that could result in poor operation: Low water flow through the unit, Low Salt level in the pool water, High salt level in the pool water. If any of these conditions exist, the system will sound a buzzer, and flash a digital code on the control panel (Model 8110) or a Red LED will light up. (Model 6110).If the condition is not addressed, the system will automatically shut itself off to prevent damage to the unit.
Sep 11, 2011 | Intex Automatic Salt Water System for ...
I have a 15x 42" intex metal frame pool an i also
Most likely you are not. The manual is very conservative!!! I have a 14000 gallon pool and I run my intex salt system during the summer at 10 to 12 hrs pump and 8 to 10 hrs chlorination in between those 12 hrs and my pool stays very clear. But..... If you don't clean the unit and let it alarm for low flow, low salt or not run the unit log enough, you WILL HAVE GREEN WATER!!!
Hope this helps, If it does, please rate the tip!
Jul 22, 2011 | Intex Automatic Salt Water System for ...
Pool pump shutting off/tripping the circuit breaker
What kind of pump are you using?
Sounds like the Intex is restricting water flow there by heating up your pump and shutting it down..
You may need to re plumb everything to handle the flow.
Intex hoses and fittings are different than the industry standards just so the can make you buy from them
Do what ever it takes to get good flow
Jul 01, 2010 | Intex Automatic Salt Water System for ...
I cannot find user manual for my intex salt water system. What side of pump does it attach to?
You have an inlet side, (where pool water is brought into the pump), and is typically the lower of the two. Then you have the return, (where the water comes back out after being filtered). As the previous person noted, you'll need to observe the arrows indicating flow direction on the SWG and it will be on the return side of the pool. Additionally, you can go to the INTEX website, and they have the same setup video that should have been provided with your system. Hope this helps.
May 15, 2010 | Intex Automatic Salt Water System for ...
Intex Plunger Valve & Straniner Basket set for 18' or larger pool set & Model# 51, 635, 633, 520R Filter Pump Logo
471 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
