Question about GE JTP20 Electric Single Oven
F9 error code while cleaning. What is broken?
  • 6,784 Answers
HI, this is a lock switch mechanism failure.
Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
If the wiring is connected properly, simply replace the door lock switch.
***(It is possible that is is stuck. trying correcting this before purchasing a new switch)---(Highly uncommon)
Posted on Jul 15, 2009
After is used the self-cleaning f9 error code
F9 code is a door latch error code. Either the latch motor or latch didn't get reset. Check the wiring to the latch motor and make sure everything is connected. Also try flipping the breaker and leaving it off for five or ten minutes, see if it might reset itself. If that doesn't work, you can have a latch motor gone bad, a harness issue, or possibly an electronic board that has shorted during the cleaning or operation programs.
Oct 24, 2013 | LG LWD3081ST Electric Double Oven
What does the F-9 code for a Ge oven mean
An F9 error code on a General Electric (GE) oven indicates that the oven's electronic control system has detected a problem with the automatic door lock. The automatic door lock mechanism prevents the oven door from being opened when the oven is set for "Clean" mode. The malfunction may be a jammed door lock mechanism, a pinched or broken wire, a faulty lock switch or a fault in the control board itself.
Jun 17, 2011 | GE Ovens
I tried to "clean" the oven and only got a F9
The F9 error code indicates a problem with the oven door lock assembly. The door lock assembly will need to be checked and replaced if defective. If the door lock assembly is okay, then the electronic oven control board will need to be replaced.
Feb 07, 2011 | Maytag Ovens
What does F9 mean
Failure to clean code
I have two Monogram ovens but they are not adjacent to each other top and bottom but are separate in different areas of the counter. I did the self clean for both ovens for the first time and one oven had the F9 error code about 1 hour and 45 min into the clean and the other did not sound a code.
Jan 24, 2011 | GE Monogram ZET3058SHSS Stainless Steel...
Code f9 on frigidaire self cleaning oven. what does it mean. i went to clean the oven and the door locked and the code f9 came up and keeps beeping. i unplugged the stove for 1/2 hour and plugged it...
Hi
Thanks for using FixYa. F9 error in your oven/range indicates an issue with the door locks assembly and/or the door latch. To start with check the door lock circuit, you can also try to jump start it to see if it's working. If it's not working then the Electronic Range control has gone bad and should be replaced, if it is working then the door lock circuit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 15, 2010 | Frigidaire Ovens
F9 error message during self cleaning cycle
Hello,F9 error means there is a problem with the lock switch.Check the wiring to the door lock switch (the wire harness may be connected wrongly).Check for stuck lock switch.
Thanks
May 31, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
F9 Error during self cleaning cycle
Before you go working too hard to get you oven to go into the self clean (self destruct) mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
May 31, 2010 | Ovens
Range Cleaning Cycle not Working
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 22, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F9 error
hi there,
can you tell me the model # on your stove please?
Sep 14, 2008 | Maytag CWG3100A Gas Single Oven
Cant open door getting F9 error code
door latch failure check wires to the door latch get the motor and or replace door latch good luck
Nov 21, 2007 | Amana AOCS3040 Electric Single Oven
GE JTP20 Electric Single Oven Logo
560 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
