Question about Jura Capresso Impressa E8 Espresso/Coffee Maker
Sunbeam em6910 water level red light flashing even though heaps of water
I have a sunbeam EM 6910 I have just replaced the seal. When I power it on it goes through the warm up then the power light stays red and the machine starts pumping straight away.
I had this same problem. Turns out that tons of crawling insects had been living in my machine and caused an electrical fault. On my machine, this issue stops when the machine senses the water is empty, so you can try just removing the water level magnet from the tank. If you do, you still get the low water beeping and flashing red light. I sorted that by disconnecting the beeper and light from the main board but I had to open the machine right up for this, so that will take much more effort. Didn't really FIX the problem, but did circumvent without much loss of function (except the low water warning). See if that works.
Jun 13, 2015 | Sunbeam Cafe EM6910
Why wont red light come on EM6910 coffee machine?
Sounds like a thermostat is no longer working. Needs to be repaired!
Jul 15, 2014 | Sunbeam Cafe EM6910
Sunbeam EM6910 coffee machine .No power or lights
It's most likely the main fuse. Google "replace EM6910 fuse" and you'll find an easy guide.
Apr 09, 2014 | Sunbeam Cafe EM6910
Water light flashing
The magnet inside the float loses its magnetism with age.
Buy a replacement on eBay for a few bucks.
You cannot repair it, but the machine will continue to work fine without it - you just won't get a signal when your water is about to run out.
Feb 09, 2014 | Sunbeam Cafe EM6910
Sunbeam cafe series EM 6910 coffee machine little red light keeps flashing
That's the low water warning, triggered by a black float with a magnet inside, in the water container.
The magnet inside the float in the water tank loses its magnetism with age.
Nov 17, 2012 | Sunbeam Cafe EM6910
Red light flashing even though water tank is full
try to check the floating magnet inside of reservoir tank.
Nov 06, 2012 | Sunbeam Cafe EM6910
EM6910 - I am having problems with the pressure from the steam. Any suggestions on how to fix it.
Have a look at your manual and see if you can adjust the steam pressure. I saw it recently as I'm having trouble with the red light flashing despite the water reservoir being full. Hope this helps.
Oct 05, 2012 | Sunbeam Cafe EM6910
How to clean and descale sunbeam cafe thermoblock
red light flashing next to water meter of sunbeam coffee
series and making a noise
Mar 20, 2012 | Sunbeam Cafe EM6910
Jura Capresso Impressa E8 Espresso/Coffee Maker Logo
637 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
