Question about Apple Computers & Internet
Upgraded eMAC G4 to OS 10 and have display problem
Just upgraded an eMAC G4 to OS 10 and the display only fills part of the screen. There is a wide black margin, like a mat around a picture. When I switch the startup disk back to OS 9, the display fills the screen. No choices/can't change display settings in the Control panel when in OS 10. Thank you.
  • dines_25833 Jul 24, 2009
    There is no "geometry" tab in Preferences > Display on my computer. No choice of resolution and the Refresh Rate is grayed out and says n/a. Also, when I click on display, two screens with two different resolutions appear. Any other ideas?
    Scholar:
  • 50 Answers
You SHOULD be able to control the monitor adjustments in os 10. In the Displays section of the System Preferences, look for the "geometry" tab. Under this tab you should be able to control width and height so your display fills the entire screen.
If you still can't find it, try adjusting the resolution and refresh rates. Also use the "detect displays" button.
Posted on Jul 17, 2009
  • minespress Jul 24, 2009
    Do you have an external display connected to this eMac? That would be the only way two display windows would appear, in my experience.
    And if you do have an external monitor connected, it may not have the "geometry" tab, especially if it is a flat screen. Do neither of your display windows have the "geometry" tab?
    Does this happen with every user account? If you only have one user account, try making a new one. Log in to that account, and see if you can set up the display correctly then. If you can, then there is a problem in your first user account's display preferences. You can delete these preferences, but it is tricky. I won't go into that unless the new user account works for you. Of course, you could just use the new account and delete the old one. (but make sure to move any documents from the old account to the new one first).
My Apple eMac G4 M9425LL/A Desktop does not fill up the desktop. How can I maximize the desktop
Hi Buchi
Do you mean you get a small desktop inside the screen surround by blank space or black?
If so then I think you are reaching the end of the eMac's life.
These machines have been very good overall. Some had the dreaded capacitor problem , but Apple fixed that on affected machines by replacing the motherboard.
I have of late though seen a few eMacs with display problems. I have one here now with a very pink display - as a computer it works fine, but the display (or display electronics) is giving up.
Unfortunately it is probably not cost-effective to try to repair these machines.
One thing you can do though is connect up an external monitor.
See if you can borrow one and plug it into the video out port (the socket right at the end of the line of connectors on the side of the eMac) You'll need a suitable adaptor though.
`If that display is fine then the problem is with the tube itself, but if the problem is still there, then then the issue is probably the video board - again not worth repairing.
let us know what happens.
Nov 19, 2013 | Apple eMac Desktop
I have emac 10.2.8 with memory 640mb processor 700MHz power pc G4 . I would like to know what safari version is right one for my computer and where can i get that. plz help me.
Hi SardaIn order to upgrade your Safari you need to upgrade your OS to 10.4.11 at least.Try ebay for a copy. Once you have done that Software Update will automatically offer to update Safari to the latest version applicable.
It's not the machine - it's the OS that matters.
Aug 09, 2011 | Apple eMac G4 Desktop
MY EMAC G4 WONT PLAY FLASH PLAYER ANYMORE...
You may want to upgrade your OS to a newer system. You can also update Quicktime and that may make a difference as well.
If you're running 10.3, you may want to move up to .4.
May 04, 2010 | Apple eMac G4 Desktop
Macintosh HD will open from desktop icon but won't stay open. I can access all but applications files using finder but Macintosh HD closes when I click on applications. I recently transferred files from...
Sounds like you may have some permissions issues - I would suggest sticking in the OS disc that came with your iMac, restarting, and holding the "C" key when you hear the chime - this will make it boot off the CD. Once booted from it, go to Tools->Disk Utility, choose your disk, and do "Repair Permissions". Once that is done, you can quit the installer and restart. If that doesn't work, the next step I would recommend is running DiskWarrior, which is $99 - this is like an industrial permissions/hard drive directory repair disc, used by many professionals. If that doesn't solve it, you will likely have to back up your user data and do a fresh install of the OS from the discs you have. Good luck!
Nov 05, 2009 | Apple iMac 17" MA199LLA Desktop
EMac G4 won't boot-up after increasing memroy
All RAM chips are not equal, you may have to use a specific manufacturer. Put your old RAM chip in and see if it boots. If it does, then you need compatible RAM chips
Jun 03, 2009 | Apple eMac G4 M9425LL/A Desktop
MAC G4 won't boot - Blue screen appears
Hi Sorry to hear you are having troubles,You will need a firewire 400 cableOK, first thing you must do is reboot the eMac in TARGET mode, this means it will be recognized as an external disk. To get the eMac in TARGET mode, you must be sure the eMac is turned OFF and has a functioning keyboard connected.Power on the eMac and very very rapidly press the ( T ) key on the keyboard, be sure the caps lock button is not pressed. If all goes well, you will see the firewire logo appear larger than life on the screen.( If you are unable to get into TARGET mode, it is highly probable that the mother board of the internal hard drive is damaged and preventing the eMac from entering TARGET mode, sorry, that's the end of the line..)Once you enter TARGET mode on the eMac, connect the firewire cable to your G4 PowerBook, you can do this either while it is running or when it is off and then turn it on.
You should see the volume of your eMac internal hard drive appear on the PowerBook desktop...sometimes you need to open Disk Utilities and repair or mount the drive manually.If this all works well, copy the required files directly to your PowerBook...After that, power off both machines, disconnect them and reboot the eMac using a CD or DVD to reformat and reinstall a new system.
Mar 30, 2009 | Apple eMac G4 Desktop
EMac G4 700 512
try to download adobe flash player installer for MAC..
Jan 31, 2009 | Apple eMac G4 Desktop
EMac Screen Resolution
Hi Loteck,
In my other life, I do computer support for a major metropolitan school district. We've had quite a few eMacs that have been coming in with bad displays. We don't even try to fix them any more. They get the Airport cards, CD drives and any other spare parts like RAM upgrades pulled, then get recycled.
Probably not the answer you're looking for, but with most technology, there comes a time when fixing it isn't worth the trouble, unless it's your hobby. I wish you good luck and a better answer if it exists.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance,
Jon
Dec 18, 2008 | Apple iMac G4 Desktop
Network a G4 (OS 9) to a eMac (OS X)
OK - first, crossover cables let you network PCs together without a switch or router. I would strongly recommend returning the crossover cable and buying a router so that you can use both computers on the internet at the same time.
Second, the eMac monitor can not directly be used as a monitor for your G4 - it's not built that way. However, you can use Screen Sharing on OS X (if both have Leopard) or Apple Remote Desktop software (if you buy it) to remote control the G4 using the eMac.
You will DEFINITELY need a monitor on the G4 in order to set it up at all, so I hope you have that.
Keep in mind that you can buy, for less than $200, an LCD screen that is larger and better quality than the eMac, and it would leave the eMac useful as a second computer. Since the eMac is unlikely to work at all with Leopard, and you'd have to buy Apple Remote Desktop, you're going to spend less money by buying a separate screen for the G4.
Nov 22, 2008 | Apple eMac G4 Desktop
Unable to upgrade to system leopard on my eMac
With software and computers changing constantly-I use older software for older macs. You will continuously run into problems dealing with new software and old computers. See if you can find older versions that still run great rather than the creative suite. Stick with earlier system software as well. Now days 640 for memory is not much because of the increase in software space use. You can also allocate memory to certain software you use most.
Dec 29, 2007 | Apple eMac G4 Desktop
Computers & Internet Logo
204 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
