Question about Samsung LN-T405H LCD TV
Samsung la40a650ai message on screen check fan 2 the turns itself off
  • 42 Answers
This message means the TV is not being ventialated properly. For a Samsung TV it needs to be 10 cm away from any walls etc.
If the unit is in a recess, the same principal would apply.
Posted on Jul 16, 2009
  • Strogger Apr 25, 2011
    Had this happen to my LA40A650A1F as well, repaired under warranty first time ( TV 6 months old.) now 2 years later same error message has reappeared, TV is same location with plenty of ventilation.
    Original warranty return receipt from repair agent states Fan P/n# BN31-00014e was replaced.
    As my TV is now out of warranty I thought I'd repair myself, trouble is I can only find 1 fan in the unit, this fan is not spinning at all so is most probably the cause, part is ex-USA for $35 + post so will see how it goes. Hopefully its fan N# 2 like the error message states.
Samsung DLP TV, model HL67A750A1F fan #3 message then turns itself off
Please check the all fan if working properly if all works fine you have defective board inside behind fan # 3 you need to replace it..
Dec 13, 2011 | Samsung DLP HL-P5663W 56" TV
I keep getting "check Fan #1" on my Samsung HL-T5087SA DLP TV. I vacuumed it and it is still doing it. Anybody know how to fix it. TV goes off by itself after a few minutes.
you need to test the fan if it is working or not or better replace the fan with a new one.there must be shortage of voltage coming from the fan thats why the unit turn itself off.over heating of components near the fan might be the cause because your fan is malfuntioning thats why you got a keep getting the message check the fan better replace it..
Jun 26, 2010 | Samsung Televison & Video
Samsung hl-s4666w DLP "Check Fan #2" on-screen message appears before shutting off. How do I fix this?
Look at the Large Lamp fan and if it is not rotating it is bad and needs to be replaced. If is ok then check the other two smaller fans. You do have a bad fan.
Apr 03, 2010 | Samsung HL-S4666W Television
Check Fan No. 2 Error Message
The DMD board you installed is bad. It senses the detection line from the fan and generates the error code. Try installing the old DMD board.
Mar 15, 2010 | Samsung HL-S5086W 50" HDTV
I replaced the fan # 2 after getting that error on
Which fan did samsung say was fan #2 ? As from my experience dealing with Samsung they dont know the difference between the fans but fan 2 error is usually refering to the fan under the light engine in the L7 and the L6 its the small one in the gray plastic case which blows under the ballast.
Dec 09, 2009 | Samsung HL-S6188W 61" HDTV
Samsung HL-P5063W DLP No. 1 fan problem
Defective Lamp,maybe and Ballast Board may well be the problem it is what turns Lamp on Look on line Encompass Parts Dist 1-800-638-3328 Ballast Board also has small fan mounted in front of it!
Nov 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Tv cuts off by it self. flashes message on bottom of screen check fan no. 2.
You haven't said which Samsung projector you have so I have to give you a generalised answer: The projector is overheating and going into protective mode.
Do as the message says: check the cooling fans as you won't know which one is fan no.2. Mostly it's simply the air filters which have clogged with dust and they're always easy to remove and clean. If you wash the filters they must be bone dry before you reinstall them.
Oct 15, 2009 | Samsung Televison & Video
Samsung sp50l6hd it is showing up on the sceen fan 2 error can any one help?
If a “Fan error message appears on the screen:
1. Look at the fans to see if they are running while the unit is on. If not running check the connector. If the connector is good replace the fan.
2. If all fans are operating, problem is in the fan detection circuit, Actuator, Protection Board or Digital Board.
May 15, 2009 | Samsung HLN467W 46" Rear Projection HDTV
Samsung sp50l6hd projecton
If a “Check Fan” message appears on the screen:
Take a look at the fans while the unit is on. If a fan is not operating, check the connector to that fan. If the connection is good, replace the fan. If the fan is still not operating you have a problem with one of PCBs.
Samsung LN-T405H LCD TV Logo
431 people viewed this question
Henry  Thomas
Henry Thomas
