Interlock wiring i need to know the wiring combination on a door interlock on the hotpoint first edition
  • Washing Mach... Master
  • 3,463 Answers
If you can tell me the model number of washer, I may be able to help you, bearing in mind that there are several versions of Hotpoint first edition washers.
Thankyou.
Posted on Jul 15, 2009
Door lock light is flashing but will not start programe
You need to fit a new door interlock switch.. cost around £ 18 parts....
Feb 14, 2011 | Hotpoint First Edition WMA12 Front Load...
Hi, i have a hotpoint wf640 washing machine and i cant open the door.it seems like the catch has gone on the interlocking door as ive tried to push the door in but still no go. Is this something i can fix...
if there is water in the drum it wont open, so you need to drop the drain hose low to gravity drain....then the door should open. sometimes this fault is due to a broken door catch utube is quite good for fitting help.
Jan 08, 2018 | Hotpoint First Edition FEW12 Front Load...
Hotpoint Washing Machine Door Interlock (how to wire up)? I have removed the old door interlock and forgot to make a note of where the wires go, (wont make that mistake again) I have 3 wires White Brown...
The three wires you should have are
1-Brown-goes to L
2 Thin black to N
3 White to C..
Hotpoint never have incorporated a wiring diagram on any of their british made appliances, so previous comments made do not apply in this case.
Hope this helps.
Jan 03, 2010 | Washing Machines
Washing machine door wont open - hotpoint
Never reach inside the washing machine with it connected to the mains. The door interlock is always live.
There are several reasons why a Hotpoint door could be jammed shut.
•A broken door catch or door frame where the door catch screws in (they are rubbish on many Hotpoints - always breaking) you can sometimes get the door open if you push the door firmly in as you open it
•If there is water still inside the washing machine, then the door wont open either on these Hotpoint washing machines (not on some others though) If this is the case, when you try to open the door the ****** won't try to move down at all. You can open the door usually if you drain the machine. (only applicable with door interlocks that have a rubber pressure hose attached to them)
•A faulty door interlock
•The pressure chamber can be blocked on some earlier Hotpoint washing machines which gives the same effect as having water in the machine. Basically the washer "thinks" there is water in when there isn't. This would require the washing machine being stripped down to remove and clean the pressure chamber bottle. This cause is only applicable to washing machines where a small rubber hose is connected to the door interlock. This hose allows the door mechanism to be locked and unlocked by air pressure activated by water rising inside the pressure chamber bottle attached at the other end on the tub. Gunge can block the very small aperture where the pressure hose fits to the pressure chamber bottle.
Thanks for contacting fixya.com
Nov 07, 2009 | Hotpoint First Edition FEW12 Front Load...
Washer wont start hotpoint first edition 800, WM51
If you have established that the washer is getting power, then I would suspect that the door interlock is the cause of the trouble., try fitting a new one.
Please rate my solution.
Thanks.
Nov 04, 2009 | Hotpoint Dryers
Microwave has power turn table works won't heat hotpoint model rvm1435bd 001
Check your door satey interlock switches.
If these switches fail (do you open the door while the machine is cooking?), the microwave doesnt know the door is shut and will not turn on the magnatron.
If you need more help, let me know.
a
Sep 27, 2009 | Hotpoint Microwave Ovens
My hotpoint few10 washing machine wont work,it wont come on at all and none of the lights at the front come on
On some front load clothes washers, the door has a safety interlock switch that prevents the washer from operating if the door is not fully closed (or the door / safety interlock switch is not aligned or broken.)
I would check that first. Please report back, OK?
Apr 20, 2009 | Hotpoint First Edition FEW10P Front Load...
Hotpoint Aquarius WF320
interlock is device which prevents door opening when machine is operating. why do you want to change it?
to access interlock. remove door gasket from cabinet in area of door handle and interlock is held by 2 screws from outside
Aug 08, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
