Question about Crown Audio Players & Recorders
I have a CE-1000. When turned on, it acts normally, the front lights flicker a second, then just the pilot light is on anbd it's putting out. Same thing now, only no output, no speaker hum, zilch. Reset button does nothing. Could it be a fuse?
MicrowaveSvc
  • 9098 Answers
SOURCE: 1800 XL JVM1860BD - won't work
It sounds like your controller may be failing. Or it could be an electrical line problem. Any other electrical itmes giving you trouble? Has anyone measured the voltage level of your power line? It should be around 110-125 volts AC. If it's significantly lower or higher, you may have a bad connection in your breaker panel or in the wiring leading to the home.
Posted on Sep 28, 2007
marsrover
  • 682 Answers
SOURCE: no output from the speaker
please check first your input source and confirm it is ok.-check speaker button is pressed(if you have one)-speaker cables are connected firmly-from amp side and speaker side-check mute button(also if you have one)is not pressed.-make reset for your system(power off and on).
if all above can not fix your problem you have to ask for help from service center.
Posted on Jul 23, 2008
  • 5 Answers
SOURCE: loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Posted on Dec 16, 2008
SOURCE: head lights and dash lights flickering on and off while driving
just replaced headlight switch and took care of problem
Posted on Jan 27, 2009
SOURCE: LG front loading washer is turning itself on,then off
You have a fault microprocessor, or the "Brain" is sporadically faulting... You need to get this looked at... it isn't a minor thing unfortunately... look get a firm "Quote" from a reliable service center man
Posted on Feb 01, 2010
My water heater pilot light won't stay lit
I would try cleaning the thermo couple surfaces with some steel wool... Both where the flame contacts the sensor, and the electrical contacts. Even a small increase in voltage may be enough to hold the pilot valve open. Both black, and white soot on the sensor end, can act as an temperature insulator, lowering the output voltage.
As for finding the part numbers for replacement: http://www.reliancewaterheaters.com/media/48391/242117_RPPCR01111-Reliance-Parts-Catalog.pdf
Feb 17, 2016 | Water Water Heaters
Mitsibushi WD-60638 , just replaced the lamp now tv flickers and shuts off with a solid red led light , can anyone help me fix this ?
not sure but check internal fan is functioning correctly...I had same problem with a hitachi
Feb 23, 2013 | Televison & Video
2005 Dodge Neon Oil Pressure light flickers at 1000 RPM or lower
check oil pressure switch located on side of engine block. not sure what side on a neon.
Nov 16, 2012 | Dodge Cars & Trucks
Ive tried to ignite the hot water gas cylinder and im not how do i know if its even working.? Cause we cant see the pilot light.?
it will all depend on what brand the hot water service is
although you should be able to put the dial on pilot light setting which is normally light an * on the dial
hold the dial down whilst pressing the clicker (piezo ignitor) normally can take between 10-60 seconds then turn the dial clockwise to the on position and turn your temp gauge with numbers to around 4-5 and it should make a noise when the heater ignites !!!!!
see how you go
luke the plumber
Mar 13, 2011 | Heating & Cooling
I have a Rheem Power Vent propane water heater model3 21VP4OE-1P that is acting up. The pilot lights and then the burner lights, but goes off after 5 - 10 seconds. It cycles like this 2 or 3 times, then...
check the thermal coupling for the pilot light. if it goes out it will shut down gas supply, its a safety feature to put out pilot light if the thermal coupling is bad. to prevent gas from leaking and causeing a fire. check coupling.
Aug 12, 2010 | Water Heaters
Hello, My Rheem hot water heaters pilot light
make sure that it is pushed into the flame of pilot light good because if not it can cool off and go out.and make sure that no drafts are getting in to heater to blow pilot.like when you close or open the front or back door have someone open them while you watch pilot light to see if it flickers .
Oct 26, 2009 | Water Heaters
Dayton 3e239e looking for operation manual
Normally you turn the gas valve to the pilot position, light the pilot, hold down the gas valve knob for 30-40 seconds and release. If the pilot will not stay lit replace the thermocouple. These are available ay Home Depot.
Ray
Dec 06, 2008 | Dayton (3E379) Heater
111 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
