Question about Maytag Appliances Over-the-Range Microwave Oven
Cant remove microwave
It is installed under a cabinet how can i slide it out?
  • 297 Answers
It is held in by clips,on the side or on top.most times you just need to pull real hard.
Posted on Jul 15, 2009
How do I remove a GE spacemaker model jvm130k
I assume that it's mounted below a cabinet on the mounts supplied with the microwave. If that's the case, there are four buttons on the top of the microwave in each corner. They fit into holes in the mount then slide into depressions which hold the unit in place under the cabinet.
To release the microwave push up from the bottom then try sliding it backward first. If you are able to move it, carefully slide the whole unit until it drops through the holes and is clear of the mounts.
Be very careful because the unit is pretty heavy and you'll get its full weight when it drops through the holes.
If it doesn't move when you try to slide it rearward, try sliding it sideways in either direction. The direction you must slide it in is determined by how the mounts were installed but it should slide out fairly easily once you know which way to move it.
Dec 04, 2014 | Microwave Ovens
Replace bulb
You must remove the metal cabinet around the oven, there are machine screws on the back and on the sides, take them out and the cabinet slides off. Make sure you unplug it well before you start work to replace the bulb.
Jun 21, 2012 | Baumatic BTM24 Microwave Oven
How to remove sharp 1480 microwave from the wall
If this is a built in mounted under an overhead cabinet, Just open the above cabinets and there will be 2 long screws facing downward that hold it in place, if it is a built in that is framed in then you will need to remove the frame and the brackets behind the frame that are holding it in place and then slide it out.
Aug 26, 2010 | Sharp R-1480 Microwave Oven
I NEED A 24 IN. WIDE COUNTERTOP MICROWAVE TO BE INSTALLED UNDER A CABINET. NO VENT NEEDED. I WAS NOT LOOKING FOR A DRAWER TYPE UNIT. I CANT FIND AN INSTALLATION KIT TO INSTALL ONE. THE ONLY KIT I COULD...
Sharp has a model 1214 that could work, but it is a little over 15" deep and will therefore not recess entirely into a 12" deep upper cabinet. I believe the install kit comes with it?
Jan 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Removing sharp R1831 over the counter convection microwave
the two long rectangular rod should slide down 1" to 1.5" unlocks the back plate and then it will slide forward and come off the wall.. hope it helps
Sep 19, 2009 | Microwave Ovens
I can't find bolts or screws that hold the unit in place. I need to remove the microwave in order to install new one.
HI there,
Here's HOW;
  1. Remove the face plate above the door.
  2. There were 2 bolts in which you will need a screw driver to loosen it
  3. This bolts go all the way to the back of the microwave.
  4. You still need to remove the one - three screws that's above of the cabinet. You may have to jar it loose if it still stuck.
Hope this helps.
Let me know for further instructions.
Aug 04, 2009 | Microwave Ovens
Unable to locate the mounting bolts to remove my Kenmore under cabinet microwave--pls help
Your micro slides into a housing that is screwed to the wall or cabinets.
Jul 07, 2009 | Microwave Ovens
Can't remove Microwave -- GE profile jvm1090
One of two things has happened here. Either some sticky substance has your microwave stuck to the counter. If that is the case just find a long object which will slide part way under it and pry it loose.
OR, the cabinet above has settled and is resting on the top of the microwave. If that is the case, empty out that cabinet and the microwave may slide out.
if the problem is something else, get back and tell me more.
Mar 12, 2009 | GE JVM1090WW Microwave Oven
Ge spacemaker installed over stove-----need to remove it
Her is a link that I hope with work that shows the bracket and how it was installed.
PDF]
  JVM1850BH/CH/SH/WH – GE Spacemaker Over-the-Range Microwave Oven File Format: PDF/Adobe Acrobat - View as HTML
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag Appliances Over-the-Range Microwave Oven Logo
109 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
