Question about Nextel i730
Airplane mode The airplane mode on my daughters phone keeps coming on when it is power up after charging and sometimes when sitting dormant. Even though you turn it off in the settings mode it continues to do this.
  • Anonymous Dec 05, 2007
    My I710 has been doing the same thing the past couple of weeks. I'd say 4 times now, it's switched itself to airplane mode. For no apparent reason! I'm really getting frustrated. Hope someone can explain why it's happening.
  • Anonymous Sep 08, 2008
    screen
I have found that if you press and hold the power key when turning on the phone, it can activate the airplane mode. Try to press and release it when turning it on to stop this problem.
Posted on Jul 10, 2008
Also just make sure you have the ariplane mode off in the settings
Posted on Oct 01, 2008
    New Friend:
  • 133 Answers
It usually means the phone has incurred liquid damage have the phone check at a service center. There is no real long lasting fix for a liquid damaged phone
Posted on Dec 07, 2007
Turn off airplane mode
On what make and model?
Sep 06, 2017 | Cell Phones
Irola tablet stuck in airplane mode.can't turn off airplane mode
You have to do a hard reset its not seing your sim card ask me how if you don't know how
Jan 29, 2016 | Cell Phones
When i am talking on the phone, it goes to airplane mode and i cannot use the phone...how do i fix or lock the screen or get the airplane mode off of the quick touches
This will help to reduce the frequency of this issue occurring. I have the same problem and have not yet found a way to remove the Airplane Mode option form the action bar pull-down for the Z998 phone. It is a ZTE firmware issue, not Android.
UNDERSTAND WHAT HAPPENS: when the phone moves slightly away from your ear while talking, the proximity sensor detects that it is not close to your face and it turns the display back on as it should. The screen often comes on with the action bar pulled down and thus all the controls exposed. A moment later your phone touches your ear before the proximity sensor had caused the screen to go blank again, so whatever your ear touches, can become an actual user command, even though unintentional. Unfortunately the Airplane Mode is one of the first selectable options on the Action Bar. You might sometimes notice that Bluetooth, Sound or Mobile Data gets toggle also; at least that does not cause you the dropped call. The problem gets worse when you walk or move around or fidget a lot while talking.
THIS HELPS: manually turn the screen off (press the power button) after you answer the call. Because you deliberately power off the screen, the proximity sensor is bypassed. The job of the proximity sensor is to turn on/off the screen to save battery (the reason of course that when the phone is against your ear, you cannot possibly also look at the screen, hence the proximity sensor turns it off for you). You will soon get in the habit.
Apr 01, 2014 | AT&T GoPhone Z998 4G
My wifi on my phone wont turn on
did you double check that you don't have it in airplane mode?
Nov 10, 2013 | HTC Explorer A310e 3g Wifi Android...
I have the airplane mode on and it won't come off .I can't receive calls..the airplane mode keep going on and off by it self even I tried to puch it on and back on it still have the same problem.I...
Try this
first check your sim card is not loose.
Try changing your profile manually from stting- profile.
IF that doesn't help.
try to do factory setting. make sure you sav your data
before you do restore.
Oct 06, 2011 | LG GT540 Cell Phone
What is airplane mode and how do i get out of it??
Airplane Mode (Motorola CLIQ™ with MOTOBLUR™)
NOTE: Airplane mode turns off the wireless radio. This allows you to use programs while travelling on an airplane, but not make or receive calls. An Airplane icon appears on top of the signal bar when airplane mode is active.
To turn Airplane mode on or off, refer to the following:
Using the Lock key
To use the Lock key to turn off Airplane mode, perform the following steps:
1. At the Home screen, press and hold the Power/Lock key on the right side of your phone.
2. At Airplane mode, tap On or Off.
Using the Settings menu
To turn the Airplane mode on or off using the Settings menu, perform the following steps:
1. At the Home screen, press the Menu key.
2. Tap Settings.
3. Tap Wireless controls.
4. Tap Airplane mode to turn on or off.
Dec 04, 2010 | Motorola Mobility CLIQ Cell Phone
About my Daughter phone
Check with your operator for 'firmware updates'.
That will address many problems.
May 08, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Airplane Mode..
Here is the link to the user manual; http://www.nextel.com/assets/pdfs/en/support/guides/phones/i265/ug.pdf Check page 119 of the manual (129 of the pdf)says: "Sometimes you may want to have your phone on,but turn off its ability to make and receive calls, such as when you are on an airplane. To set your phone so that it cannot make or receive phone calls, Direct Connect calls, Group Connect calls, Talkgroup Calls; or transfer data: 1 From the main menu, select Settings > Advanced > Airplane Mode. 2 Set this option to On. This icon U appears. Note: Pressing p for more than 5 seconds also turns on Airplane mode. To restore your phone?s ability to do all these things: Set this option to Off." Hope this helps :)
Jun 29, 2007 | Nextel i265
Cell Phones Logo
498 people viewed this question
Top Nextel Cell Phones Experts
Rommel Balcita
Computer Repairing
Computer Repairing
ray gallant
Are you a Nextel Cell Phone Expert? Answer questions, earn points and help others
