Question about Water Sport
Where can I purchase a replacement bladder for Obrien wakewarrior
This is a water tow tube wake warrior 3 person tube
2 Suggested Answers
SOURCE: airhead 3 person tube
Put weight (people) on the rear of tube as far as possible and start out at full throttle until they are moving sufficently to stay on top of the water. Make sure tube is fully inflated.
Posted on Sep 09, 2009
Where do I put the 100 oz. Hydrastorm water bladder and route the drinking tube?
jetblackrave-
In what type of backpack are you trying to use the water bladder? The hydrastorm is most effective in a pack designed for a water bladder. A pack designed for a drinking system willhave two things: 1) a pouch on the inside of the pack that will hold the bladder in a vertical position, against the back, and 2) an opening (usually a small hole on the left/right/or on both sides). A pack without these features can work with a bladder but less effectively. Worst case, you can always make modifications to your pack to make it work with a drinking bladder.
Hope this helps.
DIYpro
Apr 28, 2011 | Blackhawk Sport & Outdoor - Others
How do i replace the cap and water tank insert
The water bladder is hard to replace. The part that extends through the bottom has a "lip" on it that has to be outside of the plastic tank. I had a hard time getting it through. I rolled/folded the rest of bladder into a tube behind the hard plastic exit tube and forced it through.
Dec 12, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Can you purchase a replacement inner tue for airhead mega slice?
Cynthia,
I have the same tube and looked around and found nothing... but luckily we were within 90 day warranty period and Kwik Tech sent me a replacement air bladder. If you're not so lucky you'll have to buy the whole thing again. But if you cover is in good shape you could always sell it on ebay and help offset the cost of the new tube. I would be willing to bid on it... my cover is getting worn. robloch at hotmail dot com Hope this helps.
Jul 15, 2010 | Kwik Tek Airhead Megaslice 4Rider Tapered...
Manual says series 7901 and series 8910. Won't
In order to spray anything out of this machine, you need to have water in the bladder and water or solution in the smartmix bottle. If you don't have both, it won't work. Try this first, if it doesn't work you can access the tubing under the housing cover. You'll need a phillips screwdriver and pliers. Lay the machine handle down and take out the water bladder. There are two screws just in back of the bladder compartment; two in the middle of the compartment and two at the front of the floor noozle. You will also have to loosen and take off the round clear cover, red pinwheel and white strainer of the smart flow. (Mine is on the top left of the cover). Take the screws out and gently lift the cover up. This exposes all the tubing, the pump, etc.
I took off each hose separately and used an air canister to make sure the tubes weren't clogged. I just couldn't figure out how to get to the two ends that go into the inside of the wheel.
I hope this helps.
May 19, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
GE Profile Refrigerator leaks
How long have the filter been inside the refrigerator, if 3-6 months that is usually the life of the filter and it is time for replacing, it is common for the filter to leak once it has reach it life expectency
Dec 13, 2009 | GE Profile PSW26P Stainless Steel Side by...
Problem cleaning the camelbak tube
No, don't bother trying, it's glued. If it's really filthy the tube brush should go all the way through.
Personally I use a weak solution of Milton (the stuff for cleaning babies bottles) with fairly warm water and let it sit for a couple of hours, turning it over every now and then.
If you have mould/mildew in the tube you probably won't ever get it clean. The only solution to that is to rinse and drip dry the bladder regularly and never store it for more than a day or two with moisture trapped in it.
Apr 05, 2009 | Winter Sports
From what is an Inflatable Towable made of?
AN INFLATABLE WATER TUBE IS GENERALLY CONSTRUCTED FROM AN ENCLOSED FLEXIBLE PVC RUBBER BLADDER AND SURROUNDED BY A NYLON FABRIC COVER. MOST TUBES CONTAIN A VALVE THAT ALLOWS THE RIDER TO INFLATE THE TUBE MANUALLY OR BY WAY OF AN AIR PUMP. RIDERS SHOULD LOOK FOR TUBES THAT HAVE ENOUGH HANDLES TO ALLOW THE RIDERS TO SAFELY AND COMFORTABLEY RIDE.
Dec 01, 2008 | 3M SportsStuff Speedzone 3 Inflatable...
Water Sport Logo
707 people viewed this question
Top Water Sport Experts
Bill Boyd
Tom Chichester
Are you a Water Sport Expert? Answer questions, earn points and help others
