Question about Dometic Rooftop RV Air Conditioner
Therma stat not working
I have a problem with my therm not working when unit is moved it sometimes loses power. Does not seem to have any control voltge going to it. I have power at unit. Where is the transformer for unit and what is the voltage sopposed to be.
    Scholar:
  • 91 Answers
If you turn electric off to unit, you can take thermostat off wall and inspect wiring. It sounds as if yo may have a short in the low voltage wiring. Each wire has to be totally secured. If there is nothing obvious make notation of where each wire goes to, then remove wires, there should be wires designated r g y twist these conductors together in a wire nut and then turn the breaker back on, if the unit runs properly you need to change out your thermostat. If it still has the same problem you may have a short in your thermostat wiring. If you have enough wire you can (turn electric off)cut back a couple inches and restrip the wire the way it was, and reattach to thermostat. The transformer is probably still good if it comes on sometimes. But you may need to check the other end of themostat wire, take off plastic shroud up above and trace where wire goes and inspect, reconnect if anything looks loose. Good luck and be safe, always de-energize to work on.
Posted on Jul 15, 2009
I have a duo therm ac unit on 2003 gbm f53 fan only works in the on position not in the auto also unit will not shut at stat only with breaker any clue
First you may check the t-stat settings if its a digital tstat. Some t-stats need to be "set up" for your unit. The configuration of the t stat may be for a gas furnace (which controls its own blower) and you may need it to be configured for an electric (heat&cool) unit which the t-stat controls the blower operation. As for the non stop operation that could be a normally open switching relay that is stuck closed. Or numerous other situations. Can't help much there.
May 29, 2015 | Heating & Cooling
"Check drain" light is on
If the float switch is indicating a full drain pan, the light will be on and the compressor and fan will not run. Make sure the dehumidifier is installed level and the condensate drain is open allowing the drain pan to empty. Next check that the float is free to move up and down and the switch operates a required. Call the manufacturer at 1-800-533-7533 for parts and instructions if there is a problem wirh the float switch.
Aug 06, 2011 | Therma-Stor Santa Fe Compact Dehumidifier...
I have a Goodman airhandler model #A24-10, serial #9305071035 and can not get fan motor to cut off except by turning off breaker. Ihave replaced two sequencers and checked out all 24volt wires to...
https://www.wedclix.com/wp-content/uploads/2017/12/aept-aepf-thermostat-control-wiring-central-air-and-heat-diagram.jpg
Let me know if this is the diagram u looking at?
Jan 05, 2018 | Goodman Heating & Cooling
I have a 2005 Pilgram 27 foot 5th wheel. My Duo Therm AC unit makes a ticking sound from the ac unit itself when it's not running. Shutting off the Duo Therm analog thermostat does not stop the ticking...
It's obviously on the 12voltDC circuit of the AC unit. Sounds like thermostat, or a relay in control box is faulty or bad connection. If you remove cover on ceiling assy., you should be able to hear it in the control box. There should be a model number on the ceiling assy., get back to me with that number and I can better pinpoint which relay. Also, try moving all thermostat buttons and temperature controls back and forth quickly to see if it may clean off a dirty circuit in thermostat as well. Make sure your AC hydro breaker is off when working with ceiling assy. just to be safe.
Mar 26, 2010 | Dometic Rooftop RV Air Conditioner
Duo Therm AC won't cut off with thermostat
Hi, sounds to me like the thermostat is at fault.You have done nothing wrong to it but cover it up. The t-stat is what controls it, turns it on and off. The only other thing that would keep it on all the time would be that the thermostat wiring could be touching together from the stat up to the unit. You might check that before replacing stat. I have seen this many times.You can start the unit and go up top and disconnect the stat wire and it should stop the unit.Then its either the wire or stat.Let me know what you find,
Sincerely,Shastalaker7
Nov 04, 2009 | Heating & Cooling
Overheating boiling over, cant find therm stat location on discovery model
Find where the Upper Radiator hose connects to the block. That is usually where you find the Thermastat. 2 to 3 bolts hold the cover in place. You need new Therma stat, a new seal, and the tools to remove and install the part.
Oct 07, 2009 | 2003 Land Rover Discovery
Crazy Heat
I think that I would change out the thermostat only due to the symptoms you are describing. Think the control board may be fine however, the thermostat sounds as if the internal componants are going out. Good luck on your repairs
Dave
Sep 22, 2009 | Dometic Rooftop RV Air Conditioner
Relaced thermostat and therma fuse, now dryer is tooo hot
Sound like the thermostat is not working bud first check and double check the thermostat is connected properly and the wires are on correctly (not mixed up)and check the stat probe or bulb is in the correct place to pick up heat(assumeing that the stat is not a energy switch wich has no bulb)If you are not sure where the wires go there should be a diagram on the inside of the back panel or go on line to the manufacturer site and get one from them,
Hope this is of some assistance
Jan 19, 2009 | Maytag PYE2300AY Electric Dryer
Heat stays on no matter what the therm temp is set on any ideas
If the stat has an installer set up did you configure it for your specific system type? (heat pump,fossle fule,and fan control
Jan 08, 2009 | Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
125 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
