Question about Directed Electronics Dei '96 To '98 Jeep Cherokee Remote Start Interface Module
How do I wire in electrics for the leisure battery ( I have electrics for the trailer lgihts already fitted). I have been told there is a looom to wire to inside the rear light cluster but can't find out anything about this!! its a 2001 V8 model.
    Problem Solver:
  • 7 Answers
Go to 12Volt.com
Posted on Jul 21, 2009
Where does the trailer 5 pin blue wire go to and from
The blue wire is assigned to electric trailer brakes, if fitted. On small box trailers it is therefore unused.
Jun 19, 2016 | Cars & Trucks
Tip
Trailer Wiring
Hello all,
For those of you that need to wire up a trailer or have to occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, grd is white, +12vdc is black, etc), this is for you.
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are: Color, Function, Mark on the plug.
Seven wire Trailer plugs:
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
A test light and a 12VDC power source can be handy for trouble shooting.
Best regards
Mike
on Jan 09, 2010 | Cadillac Escalade Cars & Trucks
Tip
Trailer Wiring 101
Hello all,
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Jan 09, 2010 | Dodge Ram 1500 Cars & Trucks
My trailer that has electric brakes installed and a 7 prong plug connector. My Tundra has a tow package with a 7 prong plug.
One of the vehicles would also need to be fitted with a electric brake controller. If the Tundra already has one fitted then the answer would have a 99% chance of yes.
May 21, 2015 | Cars & Trucks
Mclouis tandy 672
Sound like you have a ground problem. If you hook you system power from one to another, then you need to carry the ground wire as well.
Apr 20, 2014 | Vehicle Parts & Accessories
Tip
Trailer Wiring Standards (Color Codes/Plug Marks)
Hello all,
For those of you that have or occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, ground is white, +12vdc is black, etc), this is for you.
This will show you how to wire trailers with seven, six and four pin connectors
Seven wire Trailer plugs (Large trailers with a battery and electric brakes):
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 09, 2009 | 2004 Dodge Ram 2500
Wiring diagram
Hook up the trailer to the vehicle. Under the rear bumper you will find a thick wire harness that runs from left to right or vica versa. Choose a location to strip open the harness to gain access to the different color wires. Open the trailer coupling. remove all wires and split them apart. Now start with say the right indicator light on the vehicle. Earth should be established via the grounding method of the trailer hook steel on steel of the vehicle. Connect any wire of the trailer to the now flashing right indicator light. Go through them all till the right indicator bulb flashes on the trailer. A good approach to determine which wire is active, is to make a test light from an old bulb connector some have already two wires connected ie; pos neg. neg the tester onto any part of the vehicle chassis and the pos to the now live wire. Go through them all till all wires meet up. Now go on and extend the harness by means of soldering properly and insulating that wire from the main harness to the female fitting of the trailer connector. At each connection on the fitting fit on properly the different wires and do the same to the male connector from the trailer so that all lines up inside the two connectors. Good luck
Aug 14, 2013 | 1993 Land Rover Defender
How to wire a towbar to a renault laguna ? what
If you have the Renault end, I've got the rest. I have the pinouts for 7 wire, 6 Wire and 4 Wire, One of them will fit the bill
White = Ground - 1
White = Ground - 1
Blue = Electric2_bing.gif Brakes - 2
White = Ground - GD
Red or Black (not both) = Battery2_bing.gif, aux power - A
White = Ground - GD
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Aug 14, 2010 | 2007 Renault R18
Car to trailer wiring problem
most likely the trailer wires dont match the truck wires. you will need to verify that the truck is wired correctly and then that the trailer is wired to match your truck. problems usually arise after someone has BORROWED a tralier and made the trailer wires match THEIR truck trailer wiring here is standardized but people wire them up any way the can, and it causes problems when that trailer is borrowed or sold.
Oct 03, 2009 | Toyota Land Cruiser Cars & Trucks
Trailer break lights and running lights don't work
i would use a multimeter to read each wires operation voltage before hooking up. ex. turn on turn signal, connect meter to find which wires is pulsing.
So your saying you wired the trailer yourself? yes you need the wires to both sides for brake and running. the runners have to be all connected, and the brake all connected, hot and neutral.
Mar 17, 2009 | 2002 Oldsmobile Alero
Directed Electronics Dei '96 To '98 Jeep Cherokee Remote Start Interface Module Logo
Top Directed Electronics Car Audio & Video Experts
xxxxxx xxx
Are you a Directed Electronics Car Audio and Video Expert? Answer questions, earn points and help others
