Question about Toshiba Televison & Video
How to I remove the back cover on a Toshiba 50L1350UC LED TV. I have removed all the screws as I have on dozens of other tv repairs, but can't seem to see how to remove this back cover. Thanks.
    Problem Solver:
  • 15 Answers
Check the input panel on the rear for one to two black screws that need to be removed. Some Toshiba sets also have the base attached through the cover, so the base also needs to be removed first ald then you can remove the back cover.
Posted on Aug 08, 2016
    Top Expert:
  • Toshiba Master
  • 9,098 Answers
Toshiba TV Repair - Replacing 26AV5 Backlight Inverter ...
? 2:36
https://www.youtube.com/watch?v=ZoAn6ovLVXc
Apr 22, 2013 - Uploaded by ShopJimmy.com
There are various ways to eliminate static electricity, but the most common ... Return the back cover to its original position and secure all screws. .... Hi I am having problem with my TOSHIBA46TL963 TV 3D LED TV WITH NO ...
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
? 2:20
https://www.youtube.com/watch?v=8-0nQ57Bvow
Mar 21, 2012 - Uploaded by rstarre ten g
Free Fix For Toshiba 50" TV That Will Not Turn On. ... Removeall; Disconnect. Watch Queue. Queue ... p.s. could they put more screws in that back panel? .... Now the TV turns on, so does theLED backlight, but NO PICTURE!
Toshiba TV Repair - How to Replace 75021540 Main Board ...
? 2:38
https://www.youtube.com/watch?v=AUOAQR_raTA
Feb 28, 2013 - Uploaded by ShopJimmy.com
Toshiba TV Repair Main Board Replacement for LCD TV Fix No ... Unscrew and remove the back cover. ... LCD & LED TVRepair - No Image & Blank Black Screen Flashlight Test - How to Fix LCD & LED TVs - Duration: 5:56.
Posted on Jan 17, 2016
SOURCE:
SOURCE: how to get pedestal off a toshiba 32 HL 67
Take out 5 HEX head screws and one black screw from jack pack cover. the pedestal will slide out from bottom. You do not need to remove jack pack cover as it is part of entire back panel.
Posted on May 22, 2008
shaggyrat
  • 1224 Answers
SOURCE: remove tv from wall mount
there is an anti theft device on the wall mounts you need the manual to adjust mount to take off
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=255670bad135aec3653b726b698def9d&q=Samsung+PDP4294
heres the link just follow instructions to get download i will also be posting it here on fixya too
this the manual
Posted on May 26, 2008
  • 15 Answers
SOURCE: tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
Posted on Sep 06, 2008
  • 187 Answers
SOURCE: the screws broke off when trying to remove the tv stand from my LG 42lg30. Is there any other way to remove the base stand? thanks
If you broke one of the base stand screw you will need to do as follow:
Remove the remaining screws of the stand and try to remove the stand, if you cant you will need to remove the back cover of the TV and then you will be able to remove the stand, remove the broken screw and put it all back.
It is pretty easy but if you feel you cant do it let me know and I can give you a detailed step by step guide.
Posted on May 27, 2009
SOURCE: Insignia TV stand screws
Had same problem with Insignia TV...#12 - 24 x 1/2" machine screws...found at Home Depot in bagged items (can't use longer because some of the holes don't go all the way thru)
Posted on Jun 19, 2009
How do I remove back cover from Vizio E601i-a3 60" tv once all screws are removed? Still seems tight around the edges? Thanks
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Disassemble procedure to many popular devices are given with illustrations.
Dec 28, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
My Proscan LED TV has a black screen when you turn it on but has a glow when room is dark. The sound works. The model number is PLDED3273A-C. This problem occurred when relative was doing something with...
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Feb 04, 2015 | Curtis Proscan 32" LED 1080p 60hz 8ms...
I need to remove the stand from my Toshiba 37HL67 so I can mount it on the wall. Can you help me. Auburn Abenton716@aol.com
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface.
Note:
Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand a way from the TV (Remorve 5, 4mm or 5/32" Allen Bolts from back of TV.)
For Mordels
26HL67
32HL67
32HL67U
37HL67 = My TV
42HL67
Herb
Sep 22, 2011 | Toshiba 37HL67 37 in. LCD HDTV
How do you remove the base stand from a toshiba 46lx177?
First, carefully lay the face of the TV down on a soft surface with the stand protruding over the edge of the surface, then remove jack panel cover on the back of the TV to expose the 5 screws holding the base on. Remove those screws and slide the base away from the unit. These instructions are also found on page 5 of your owners manual.
Jan 29, 2011 | Toshiba 46LX177 46 in. LCD HDTV
HOW DO I REMOVE THE SCREEN COVER FROM A TOSHIBA TV MODEL TW65H80
some sets have screws in the back all around the front cover and some come off by taking bottom speaker grill off first and you will see screws that holds the cover. And some have a template that pops off and screws are underneath it.
Dec 26, 2010 | Toshiba TW65H80 TV
Red light blinking and no response akai LCT2715
The led is blinking due to fault in power supply board.
On the power supply board there are some capacitors and ICs .if any of those gets short or faulty the power supply board will create problems and the red light will start blinking. The components on the board needs to be checked with the help of multimeter and continuity tester.And the faulty components needs to be replaced with the help of soldering iron. the procedure to check the power supply board is as follows:---- 1) You are going to need a Phillips ( X ) Screwdriver for this procedure. The first thing you will want to do is find a suitable location to disassemble the TV. Try to find somewhere with plenty of space to work and preferably somewhere you will not have any hazards such as static (like carpet)
Lay the TV Flat on its face (picture side down) and remove the 4 screws from the back of the TV holding the base on.
Next you will want to process to remove the screws around the back cover. There are 12 screws you will need to remove (refer to picture for locations).
Carefully remove the back panel of the TV. It may snag on the coaxial connector so be careful.
2) Once you have the back off of the TV you can see the Main board and power supply covers.You will now need to remove the left (right side from the back) speaker cover to allow access to two of the screws holding the Power Supply Cover in place. This is easy and pretty straight forward and has 8 screws around the perimeter.
Once you have the speaker cover off you should be able to access the screws on the side and you will also want to remove the other screws from around the sides of the cover. Some TV's I have worked on only had 6 where others had 7 or 8. Just make sure to remove all of the screws before trying to remove the cover.
Once you have the cover removed you will see the Power supply. Remove the wiring harnesses from the power supply board. You will have 4 cables at the top of the power supply and one main power input at the bottom. The main power input may have some glue securing it in place. Simply cut this with a knife or pull it loose.
Once you have the cables off of the power supply you can remove it from the TV via the screws on the 4 corners. Be careful not to damage anything as you remove these screws. You now have the Power Supply removed from the TV.
you can now get the power supply repaired from any local tv repair technician.or get new replacement power supply from the service center.or from online stores like : www.partstore.com or from www.shopjimmy.com
Thanks. you can rate this solution and show your appreciation.
May 13, 2010 | Akai LCT2715 27 in. LCD Television
My tv was accidentally unplugged while it was still on and when i turned it back on there is audio no video and the green light just flashes next the to the red light and the tv turns on and off by itself...
Hi
Thanks for using FixYa. From what you have described it seems to be a shutdown circuit problem, and a problem in the section of the TV that provides High Voltage to drive the raster creating circuitry. Usually the issue is with the bulb going bad however, as you have already replaced the bulb few months back, so in your case this would also be the DLP related circuitry which includes the light engine (white light bulb/Color wheel drive circuitry or LED array, DLP chip and associated circuitry). If you want to do the repair yourself then it is highly recommended that you should have knowledge of internal circuitry of the TV, if not then it is always better to take assistance from a qualified repair tech. The cost of repair will be around $300 including labor if you get it done by a professional.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 17, 2010 | Toshiba 52HM95 52" HDTV Projection...
Question on toshiba tv - fixya post
Found this on the www.Toshiba.com website. Q. How do you remove the stand?
Models: 26HL37, 26HL47, 32HL17, 37HL17, 42HL17, 32HL37, 26HL67, 32HL67, 37HL67, 42HL167, 42HL67,
47HL167, 52HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00078
1. Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface. NOTE: Extreme care should always be used when removing the pedestal
2. Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can
3. Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4. Once you have removed the five screws holding the pedestal stand in place, remove the stand from the TV by
sliding the stand away from the TV. The Toshiba customer service number is 1-800-631-3811. Hope this helps you with your problem.
Dec 22, 2008 | Toshiba 42HL167 42 in. LCD Television
Remove swivel stand
There's likely a plastic cover on the back of the swivel stand. If so, remove it and you will find four to eight phillips screws. Take them out and the stand should come free. If there is no plastic cover, then there should be some screws in the back cover that go through the back cover and into the support. Remove the screws and gently remove the stand. Good luck. David
Sep 05, 2008 | Toshiba REGZA 46RV530U LCD TV
How to get pedestal off a toshiba 32 HL 67
Mar 05, 2008 | Toshiba 32HL67 32 in. LCD Television
Televison & Video Logo
1,279 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
