Question about Dishwashers
Programme selector only works if held in position
The rotary programme selector on my adp436wh dishwasher will not work unless I put pressure on it slightly to the right.
  • 297 Answers
The sensor is starting to go bad.can't be fixed must replace unit when stops working.
Posted on Jul 15, 2009
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Dado
Jan 15, 2015 | AEG Washing Machines
Err code displayed and fails start
or counter-clockwise. The green pilot light of the button
9 starts flashing: the appliance is now switched on.
when the appliance is working, the red pilot light
of the button 9 will flash 3 times and the message Err is displayed to indicate a wrong selection.
The appliance will not perform the new selected programme.
• To switch the appliance off, turn the programme selector
dial to the position .
To cancel or change a running programme, switch the
appliance off by turning the programme selector dial to the
position
. Select the new programme by turning the selector
to the desired programme. Start the new programme
by pressing the button 9 again. The water in the tub will be
not emptied out.
Dado
Sep 25, 2014 | Zanussi Washing Machines
Electrolux dishwasher
Hello - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Nov 05, 2012 | Electrolux 24 in. ESL4125 Dishwasher
How do you remove selector knob on bosch 11255vsr
Rotate the selector to the 4 to 5 oclock position, or the 7-8 oclock postion, push the red button in all the way with a screw driver and pull the knob out. Certain model hammers you have to rotate to a slightly different position to remove the selector, you will have to try one, if it doesn't work try the other.
Dec 02, 2010 | Bosch SDS-plus BULLDOG Xtreme Rotary...
The pump works but fails to shut off. The fill
If the fill valve does not open then there should be no water to pump unless the machines pressure switch is stuck in the closed position
That would fool the machine into thinking that the machine was up to level
Remove the back of the machine , look for a thin rubber or plastic tube going from the bottom of the drum to a small flying saucer shaped object near the top of the unit
Take the pipe off at the base and blow into it , you should hear a click , when you remove the pressure you should hear another click, if you do then the switch is working mechanically.
Turn the machine on and with the pipe still removed and see if the pump is still running if it is it is then you need to check out the pressure switch and the programmer
Mar 14, 2010 | Viking 24 in. Professional Series VUD040...
I have a Miele G641 dishwasher and it wont drain and it is coming up with red lights saying inlet/outlet, salt intake
One thing these guys did not point out is to turn the knob to STOP before starting this procedure (otherwise you will be ignored) Once done this works fine.
-- from the manual ----------------
Before rectifying the problem you must:
- Turn the programme selector to the "Stop" position.
- Switch the dishwasher off using the "On/Off" button.
Nov 15, 2009 | Miele 24 in. Novotronic G641 Plus Built-In...
CDA dishwasher (model number CW496) , stops working at the rinse cycle, and does not empty, filter is ok, tried re-setting the programme but unless there is no water being held the programme won`t work
my dishwasher starts off with good intentions then a couple of minutes later it starts beeping non stop.I open the door to find it has turned on to the rinse cycle and will not do its job.I continue to start it again and then it repeats the problem again.Can you help?
Sep 21, 2009 | Dishwashers
Rotary jets not spinning
Hi there........Rotary jets not sinning can be caused by....(a) something impeding their rotation..dishwasher air freshner hanging in incorrect place...(b).incorrect position of upper tray resulting in large plates impeding spray arm rotation...(c).cuttlery basket incorrectly placed or loaded with cuttlery impeding spray arm...(d) wash pump blocked or damaged impeller resulting in insufficient pressure to spray arms...
regards Sir Galahad
Aug 12, 2009 | Dishwashers
Shifter alignment cable is out of place, how do i fix it ? If I put the car in drive it roles backwards. I have to drive with the car on 4.
To Adjust : 1- Unclip parking brake boot. 2- Detach the center console upper section. 3- Disconnect cigar lighter electrical connector. 4- Remove te center console upper section , disconnect the transmission mode and traction control electrical connectors 5- Move the selector lever to position "R" 6- Loosen the selector cable lock nut 7- Detach the selector cable. 8- Raise and support the car. 9- Move the Rotary position switch to the "R" position , so that it matches the lever. 10- Lower the car. 11- Connect the selector cable (Do not tighten selector lever lock nut) 12- Move selector lever to "D" , hold the selector lever applying light pressure and fingure tighten the rear lock nut , then fingure tighten the front lock nut 13- Now move the lever to different gear positions , ( when "D" is selected , make sure it sits as close as possible to the "D" and "4" position in each corner. 14- Tighten selector lever lock nut. 15- Install center console upper section. (connect the transmission mode and traction control electrical connectors) 16- Connect the cigar lighter connector 17- Install the center console upper section. 18- Clip together the parking brake boot.
And you are done , I know it looks hard but it is not , read through my instructions and understand it and all will be easy to do. Good luck , hope it helped :)
Jul 27, 2009 | 2001 Jaguar S-Type
Hotpoint BF1620 Integrated dishwasher not working
Lets try the following hope this works
1.- unplug the appliance, isolate it from the electric supply.
2.- Remove the kitchen unit plinth and check inside the inspection panels below the door to see if there is water in the base.
If there is, sponge it out and then try the machine again.
Was this helpful?
May 07, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Dishwashers Logo
47 people viewed this question
Top Dishwashers Experts
