Question about Nortel Meridian M7208 Corded Phone
M7208n phone - mute ringer for external calls
M7208n phone - we want to stop an extension ringing when there is an external call but to be able to hear when we transfer internal calls
Incoming line ring settings are in the config menu under:
2nd option - Line access
enter extension number
2nd option - Ringing
Ringing then can be toggled on or off for each line assigned to that extension.
Mark
Posted on Oct 08, 2010
  • Bruce Perry Dec 06, 2012
    I have a meridian M7208 and do not know how to access the "config menu" to try to un-mute my extension ringer. Any ideas?
How do I turn the ringer off at my phone for external incoming calls?
Go into the extension programming and change the line settings to no ring. It is best done if you have a display phone so you can see the changes. If not, then you will need to look at the flashing line lights when you enter the programming mode.
Press Feature 00. This will take you into the programming mode. You should see the line buttons lit up green. They will be Solid (Immediate Ring) or Slow Flash (Delayed Ring) or Fast Flash (No Ring). I assume yours is solid so push each line button until it changes to a fast flash. Once done press Feature 00 to exit the system and save the settings.
Sep 11, 2014 | Avaya Lands Phones
My phone stopped ringing
You may have turned your volume very low or you may have muted your phone (turned off the ringer). Check your volume and ringer settings.
Jun 24, 2014 | Kyocera Cell Phones
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
How can I turn the ringer back on? Thank you
1 Press (MUTE/FUNCTION).
2 Scroll to “Ringer setting” by
pressing öor ñ, and press á.
3 Press áat “Ringer volume”.
4 Select the desired volume by
pressing öor ñ.
•Each time you press öor ñ, the
volume will change and ring.
To turn the ringer OFF:
press örepeatedly until “Off ?” is
displayed.
5 Press á(Save key).
•A beep sounds.
To turn the ringer ON:
Press ñin step 4.
•The ringer will sound at the LOW level.
•You can exit the programming mode any time by pressing (OFF).
•If set to OFF, “Ringer off” will be displayed while the handset is not in use.
•If you have received new calls, “Ringer off” will not be displayed but
“Received calls” will be displayed while the handset is not in use.
“Ringer off” will be displayed for about 5 seconds after completing operations
or lifting the handset from the base unit or the charger.
•You can also select the ringer volume while an external call is being received.
Press öor ñwhile the handset is just ringing.
•You can change the ringer tone for external calls. See page 49.
HIGH
MEDIUM
OFF
Ringer volume
Low High
Ringer volume
Off ?
LOW
ñ
ñ
ñ
ö
ö
ö
V.M. access
HRinger setting
Initial set
HRinger volume
Ringer tone
18
LCD
Oct 26, 2009 | Panasonic KX-TG2352 Cordless Phone
Using the T7316E in an onair studio want to have external mute
You can use Do Not Disturb feature
Feature 85 - On
Feature #85 - Off
Cheers
Jun 17, 2009 | NorStar T7316E Corded Phone
Turn off Ringer For External Calls Only
If you use strata emanager it would depend on how your system was set up. One way is to go to Advanced configuration tab Station tab, multiple call group tab, click on the group number (far right), then member tab and select extention and ringing option. Another way is to go again from the advance configuration tab, then assignment tab select the extention number on the right select key assignment tab, and on the incoming extention line double click it nd select no ring.
Jun 11, 2009 | Toshiba DKT3020SD Corded Phone
It doesn't ring
I had the same problem. If the phone is plugged into an outlet with any other device, the phone may stop ringing until you plug into an electrical outlet where it is the ONLY device using that outlet. This has worked for me
Dec 30, 2007 | GE 28112EE2 Cordless Phone
Simply want to turn ringer off at my phone for external incoming calls
How do you want to be notified? How do you determine if a call is for you? Does an operator answer the call and transfer it to your extension? If so, you just need to change programming for your phone so it does not ring for incoming calls. It would still ring if a call is transfered to you. Programming is changed in the phone system, not the telephone. Your phone can be used on different Nortel systems that program differently so you need to find out which system you have and locate the manual for that or pay a local installation company to make the changes.
Nov 08, 2007 | NorStar T7316E Corded Phone
RCA 25450RE3 - Incoming Call Ringer Setting
try turning ringer speaker volume down. if that does not work, then remove battery for 10-15 minutes and replace and try again.
Oct 12, 2007 | RCA H5450RE3 Accessory Handset For -25450...
Nortel Meridian M7208 Corded Phone Logo
1,286 people viewed this question
Top Nortel Lands Phones Experts
george  peters
george peters
David Burbee
David Burbee
Shehu Pro
Shehu Pro
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
