Question about Lenovo 3000 N100 0689 Notebook
My notebook screen 3000 n100 goes dark after few second
After few second my notebook screen became dark but external monitor work
  • Lenovo Master
  • 32,281 Answers
This could be a faulty CCFL lamp.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jul 15, 2009
    President:
  • 942 Answers
Hi..
Most laptop PCs include external video outputs, primarily VGA (Video Graphics Array), with an increasing number of devices offering DVI (Digital Visual Interface), or HDMI (High Definition Multimedia Interface) support.
When your laptop PC's built-in display isn't working properly, you can quickly and easily determine if the problem relates to the built-in graphics circuitry or to the display itself by plugging in an external monitor. If the external monitor lights up and things work as they should, the built-in display is at fault. If the external monitor also fails to work, it's likely that your laptop PC graphics circuitry has failed. Because this can involve replacing a standalone graphics module or the system board inside the laptop, depending on the make and model of your computer, you need to perform a cost-benefit analysis on making repairs or replacing your laptop PC.
Good luck !!!
Regards
PCmania
The monitor startup and few seconds later it turn
You are going to have to open up the monitor, please read below if you are going to DIY.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 21, 2010 | Samsung SyncMaster 216BW Monitor
Dell Latituse D600 display goes dark
The picture board on your monitor is faulty or bad, since it goes black after few seconds, it means the picture board of your laptop has developed fault.
The best thing for you to do now is to take the laptop to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself. in order not to complicate issues.
Take care.
Apr 21, 2010 | Dell Latitude D600 Notebook
THE SCREEN IS NOT WORKING,BUT YOU CAN SEE VERY DARK ON THE SCREEN THAT THE COMPUTER IS WORKING, I TRIED TO CONECT A EXTERNAL MONITOR, BUT IS NOT WORKING, DO I NEED TO PUSH SOMETHING, AFTER CONECT THE...
Your keyboard has a special "Function key" (printed in blue). It is probably on the lower-left, next to the special Windows key or control key.
You also have several keys along the top row, also blue.
Hold the blue [Fn] and press the upper key that resembles a monitor. Release the two keys and wait a few seconds. If the monitor does not come on, wait a few more seconds, the press the two blue keys again. It will work.
By the way, the fluorescent lamp that creates the "backlight" for your laptop screen has burned out or the cable may be loose.
Oct 05, 2009 | Computers & Internet
Screen goes dark after a few seconds
try fn+f7 that Toggle external monitor,and disconect external monitor before starting
Jun 13, 2009 | Lenovo 3000 N100 0689 Notebook
Gateway PC Notebook/Tablet Model: CX2618 Monitor Replacement
First shine a flashlight on the screen. if you can see a very faint image on the screen the problem is the backlight. If not... it could be a few other problems, first test if it works on an external monitor. If it can then you need to cleear the CMOS. to do this you unplug the cord remove the battery and hold down the ON button for 30-60 seconds, then turn it on. If it does not work on the external monitor it is probally because you have a bad video card and need to replace it.
Jan 28, 2009 | Gateway CX2618 Notebook
Acer Travelmate LCD screen went dark
The same thing happened on my HP. I ended up buying a LCD screen off ebay. That corrected the problem. New screens cost $150+. You can get one off ebay for half the price.
Jan 16, 2009 | Acer TravelMate 270XV Notebook
Compaq r3000 dark screen
If you already replaced the inverter and the screen still continues dark, you need to replace your lcd screen. Your video card is good due you have signal with external monitor.
Sep 18, 2008 | Compaq Presario R3000 Notebook
Laptop Screen dark yet computer works with external monitor
does the fan work ok? and do you have a laptop holder for it or you just have it on a desk ....get a laptop holder for it if you do not have one and as for the rest goto the power mangment area on the computer and see if the monitor might be on stand by after a few min ...
Jul 14, 2008 | Compaq Presario R3000 Notebook
Lenovo 3000 N100 0689 Notebook Logo
938 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
