I have an Asus A8N-sli delux Motherboard which I used to upgrade my existing system. On fitting the board and switching on all I got was the Green Led on the board but no video i,e, bios setup (after pressing del). I've fitted ageforce 6600GT videocard which works in my old set-up. Can you suggest anything? Harry
  • 198 Answers
You may need to switch back to Onboard AVG and reinstall your OS as you put in a new motherboard.
There was a way to replace the motherboard without reinstalling the OS, but as you have already done this, it's the only option.
Keep in mind that this motherboard only supports AMD Socket 939 Athlon 64FX/Athlon 64 processors. If everything else fails, look to this area as your problem.
Please look at this link to help you purchase proper parts for that mobo.
Posted on Jul 15, 2009
Asus a8n sli deluxe motherboard diagram manual?
Download page.
http://www.asus.com/Motherboards/AMD_Socket_939/A8NSLI_Deluxe/#download
You must choose an OS like XP. Required, but indifferent. Click on Manual and choose Global link.
Oct 14, 2012 | ASUS A8N-SLI Deluxe Motherboard
Wire green,r-out, orange l-out , jellow mic- in red mic-power and gray ground i will like to know where i have to conect these wire's thank you
Hi' As you are facing the ASUS A8N-SLI mother board check the light blue colored socket on your left side below , then look at it and you can see a guide when you insert the wire which you mean they where to be connected , Note there is also color codes on its printed board as guide for wire color coding .
Aug 14, 2011 | ASUS A8N-SLI Deluxe Motherboard
I don't know how to plug in the wires for the ASUS a8n sli deluxe motherboard
Here is the manual for your motherboard (since describing a diagram probably isn't very useful...)
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI/e2024_a8n-sli.pdf
You want to look at pages 27-35, they describe what you need to plug into the motherboard. Basically make sure you have connected:
1) 24-pin power cable (from power supply)
2) 4-pin power cable (for CPU from power supply)
3) Any case fans with 3/4 pin connectors.
3) hard drives (SATA or IDE)
4) USB front panel ports
5) Audio front panel ports
6) Case plugs (power LED, hdd LED, power switch, and reset switch).
Apr 19, 2011 | ASUS A8N-SLI Deluxe Motherboard
Does ASUS A8N-SLI DELUXE support fan speed changing?
You can research *********** board and drivers at ASUS.com.
You may find a new BIOS update which controls the fan speeds and temp.
If not, you can find plenty of frreware which will handle *********** board.
Nov 08, 2009 | ASUS A8N-SLI Deluxe Motherboard
Coolmaster cm690 asus a8n-sli deluxe
the boards today have real fine typeset near the connection pins but they are there
Jul 31, 2009 | ASUS A8N-SLI Deluxe Motherboard
ASUS EZ-PLUG not plugged in?
ASUS EZ_PLUG is optional for SLI mode...this model of your motherboard has an SLI that connect 2 video card using pci express...if this is only you problem for bugging the EZ_plug not connected,you can disable that in BIOS setup...
Oct 28, 2008 | ASUS A8N-SLI Deluxe Motherboard
Ram problems
Your memory should be in slots A-1 & B-1
You Asus board uses the Award bios. The link posted below will tell you what your beeps are saying.
http://www.bioscentral.com/beepcodes/awardbeep.htm
In your case do as I suggested above. I have two working
A8N-SLI Deluxe boards & the memory works fine in A-1 & B-1 slots.
Good luck & best wishes!
please vote.............................
Mar 14, 2008 | ASUS A8N-SLI Deluxe Motherboard
Describe your ASUS A8N-SLI Deluxe nVidia video card
Yes, you do. Your board was built with the idea to use 2 graphic boards to get great video
NVIDIA® SLI™technology revolutionizes PC performance by combining multiple PCI Express GPUs in a single and scalable system! Gamers and hardcore enthusiasts know that dual GPUs mean increased, supercharged 3D graphics and performance
Dec 09, 2007 | ASUS A8N-SLI Deluxe nVidia nForce4 SLI...
System wouldn't Boot
If your CPU or memory were an issue your Asus board would sound off with BIOS beeps. Asus uses the Award BIOS & you can see what these beeps mean at the link below. Regaurding your PC not able to boot is an issue with your PCIE/PEG video card-in relationship with BIOS setting & the SLI switch card mode that came with your board. When running 1PEG video card you must set this in the BIOS to Auto & you need your SLI switch card connected in its slot. By default, the EZ Selector card is set for a single graphic card. When you install dual PCIE graphic cards on A8N-SLI series motherboards, please make sure EZ Selector card set to the Dual Video Card side and properly inserted. Link to Award Bios beep codes: http://www.bioscentral.com/beepcodes/awardbeep.htm
Will come in handy.
Reading the FAQ's at Asus site will help you better understand your A8N-SLI Deluxe. You'll need to fill in the, "Please Select the Product" first: http://support.asus.com/faq/faq.aspx?SLanguage=en-us
Dec 05, 2007 | ASUS A8N-SLI Deluxe Motherboard
Computers & Internet Logo
David Payne
David Payne
