Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Ge oven model xl44. my oven will not lite, the broiler works fine.
    President:
  • 942 Answers
Hi..
You need to do this
  • Replace the bulb
  • Test the switch
The interior oven light in most ovens is a standard 40 watt appliance bulb. Often, to change the bulb, you first need to remove a shield or glass dome. If the bulb isn't burned out, the problem may be with the switch on the oven door frame. If the switch works poorly, intermittently, or not at all, you need to replace it.
When an indicator light has stopped working, you may be able to replace just the bulb--but you usually have to replace the entire light assembly. Alternatively, there could be a problem with your burner sensor (stuck open or closed) or your indicator light circuit.
Good luck !!
Regards
PCmania
Posted on Jul 15, 2009
2 Suggested Answers
woodchuck789
  • 4070 Answers
SOURCE: GE XL44 Oven and stovetop work - broiler does not work
The broiler is the top element in the oven. Look at it. Bad ones sometimes have burnt into or have a melted spot. If it looks ok take it out by removing the screws at the back and pull the wires out a little and unplug the element. With an ohm meter it should show continuity. Replace it if any of these things apply.
Posted on Feb 04, 2010
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
I have a GE xl44 Gas stove. Oven will light, but not maintain temp. Broiler works fine. Ideas?
heatman101
Mar 19, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Feb 04, 2010 | GE Kitchen Ranges
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE XL44 oven not working, but the broiler is...???
    CHECK THE IGNITOR, IT SHOULD BE GLOWING ORANGE BEFORE GAS IGNITES. IF NO GLOW, REPLACE IGNITOR.
    Jan 28, 2009 | GE JGRP17 Gas Single Oven
    GE Oven does not ignite, bute Broiler does.
    Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
    Oct 14, 2017 | GE JGRP20 Gas Single Oven
    GE spectra xl44 not work
    I have the Ge Xl44 stove the burners and broiler work fine but the over will not heat up. How can I resolve this problem?
    Jan 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    Ge xl44
    GE XL44... Oven does not work. It was working just fine one day & then would not work. Everything else works fine. Stove has electric ignitiion. Could it be it is not working on the oven? Any ideas?
    Jan 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE Profile Spectra JGBP90 Gas Kitchen Range Logo
    786 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Craig Butler
    Craig Butler
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
