Question about MSI K8N Neo4-F Motherboard
Hi, my pc is not giving any signals to monitor by poweron though fans are working,processor-x86,motherbard-msi,recently i have enabled cool n quiet control in integrated peripherals section of bios settings, adarsh
  • Douglessd
    Douglessd May 11, 2010
    Not sure what you mean by no signals to monitor. Do you turn your pc on and nothing at all happens? Does it make any beep codes? Some MB's have a row of lights to signify start up error conditions. If you changed a setting and it immediately stopped working then that may be your problem. Do a factory reset on *********** board. Sometimes you remove a jumper then put it back again.You might need to find the boards manual for this. You can normally download it if you don't have one. If you get stuck you might just have to pop the battery off the mother board for a minute then replace it. You will have to redo any custom config in your bios but hopefully you haven't changed too much in there. Hope this helps.
    Scholar:
  • 78 Answers
Try connecting the cable properly, check the fuse of monitor. connect ur CPU output to a CRO n check for signals...!!
thank u
Posted on Jul 15, 2009
CPU Fan
When it comes to computers and changes in system heat, the very first thing I always tell folks is to clean your computer. Dust is one of the best insulators out there so get the dust out, drop the computer's running temperature. (Oh.. and please don't use a regular vacuum cleaner unless you like dead motherboards!!)
I've come across this fan issue a couple of times now. Barring a dusty computer, it's most likely that your new hotter system is running at the same temperature as the fan setting on your motherboard. The X4 Phenom runs hotter than the X2 220 by only a slight margin but that's all it takes. I'm assuming you're comparing these at default speeds as when you overclock, your base temperatures all go out the window.
There are two solutions to this, up the temperature range of your fans or cool down your system. If your system is already running at 50C or hotter, you'll need to look at some combination of reducing internal clutter (blocks or diverts air flow), getting higher CFM fans (though not necessarily noisier.. there's some quiet fans out there), or even changing your case for one that pushes high air flow.
If your system is already running sufficiently cool, your may simply want to increase the fan temperature value in the BIOS/UEFI.
There's a bunch of good freeware tools out there to monitor your system temperatures like HWMonitor or AIDA64.
Hope this helps some.
Mar 23, 2014 | Computers & Internet
I have been using my desktop for sometime now with no problems. I powered it up one day and got no signal o the monitor, no beeps nor anything like that. The processor fan spins and keys board lights up...
Since you have tried everything else, i persure the problem is with the processor. It might not be getting the require power. If you have installed any hardware recently, try removing it and starting thr pc.
Mar 27, 2011 | Computers & Internet
Picture (.jpg) distorsion on a new monitor (aspect ratio change)
For your resolution to come up perfectly, update your graphics driver. Also if your monitor came with a disc. Install the software if any available on it.
Sep 22, 2009 | HP Compaq WF1907 Monitor
Assalaam-o-Alekum and Hello This is Bilal, I have Dell optiplex GX280 with 3.2Gh processor. Iam facing a problem with a cooling fan which install for cooling of processor. Thats run very fast after few...
Hi, I have the same computer, and the stock fan that's installed has a very high rpm. It is a variable fan that can actually be set in the bios to run in a quiet mode or in a mode that is more for heavy work, like your gaming, or other intensive work that requires a lot of processing. Other tasks that require the processor to work harder are graphics, CAD, audio recording, and video editing and viewing. You will notice on your dell, that you can actually hear the fan go through different speeds depending on how much work the processor is doing. It can get loud, and you may even think that maybe something is wrong with your fan, but that's just the fan attempting to cool the processor as it's working. This is software controlled based on the temperature reading of the processor chip. To use a quieter mode, you can enter your bios during startup, and find the fan settings. Change the fan setting to the quieter mode (it actually reads something like "quiet mode" or office mode" or something like that - very easy to determine. Then save your settings and exit bios. I need to tell you though, it's not much quieter. There are quieter fans you could buy for your CPU, but it may not be worth it to you. I had my cpu sitting on top of a side desk, and it was unreasonably loud. I plaecd it on the floor under the desk, and now I can barely hear it. Maybe you need to place your cpu further away from you in such a way. You can even get foam and "soundproof" your cpu, remembering of course, not to cover the ventilation holes in your case, or cover any part of the processor or motherboard - just the interior walls of the case. A lot of techs I know who need their processor near them (disk and rear panel access) use this technique. Hope this helps.
Jun 16, 2009 | Dell Optiplex GX280 (99301) Motherboard
Main fan on dell dimension e521 on full blast when comp on
Do you have your PC in some sort of enclosed space with little ventilation? If so, the constant fan activity is your PC trying to keep things cool inside. With little ventilation comes great heat, and PCs like it cool.
Dec 27, 2008 | Dell Dimension E521 PC Desktop
New Motherboard & Processor not working
Usually this symptom has to do or with memory modules with problems or the VGA adapter (integrated) could be damaged. First try to reset the BIOS of *********** taking out the battery and using the reset jumpers informed in the Mother Board manual. Then put the battery and the jumpers back to the factory default position and try again.
If this doesn't work, try to plug the power cord to another 220V as the ground could cause this type of problems.
You can also try to install another VGA adapter to check if you receive the VGA signal in your monitor.
Hope it helps...
Please tell us about your progress.
Best regards
Eduardo
Oct 04, 2008 | Computers & Internet
Replaced Mobo & Processor but PC not working
First step is to check and make sure that all cables are connected properly and that the RAM is seated properly. Also are you using onboard video or an add on card?
May 30, 2017 | Computers & Internet
Replaced Mobo & Processor Nothing Working
May I know the model of your gigabyte mobo, you just replaced your unit with.
'cause it may not be compatible with the new power suply you have upgraded with.
Thanks
Sep 26, 2008 | Computers & Internet
New Mobo & Processor but nothing happening
You need to have a PSU greater than 450watts. that could be the problem..
Sep 22, 2008 | Computers & Internet
New Mobo & Processor but no Bleeps etc
Could be the power supply is not strong enough to power the system. Replace the power supply with one that is between 350 - 450 watts. This should provide ample power to the system.
Aug 05, 2008 | Computers & Internet
MSI K8N Neo4-F Motherboard Logo
182 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
