Question about Standard (CRT) Televisions
No picture color started to go funny then next time I turn it on no picture. lights om the front panel will blink on and off serveral times and tv makes a buzzing sound
  • 4,102 Answers
Re: no picture
This sounds like a solder problem this can be hard to find yourself and probably would need a pro to look at it it should be cheap to repair and should just be a case of resoldering the bad solder hope this is some help to you if the infra red display flashes then it probably a problem in the low voltage area but it can be hard to find the prob without a resistance meter and these are not cheap to buy so i would let a pro look at it for you hope this is some help.........................................
Posted on Nov 17, 2007
0 characters
3 Points
Tv is 10yrs old. Started with color only red and blue, standby blinking, now nothing. Had something like this long time ago is this worth fixing?
propably green not working. due to age its hard decision its worth or not to repair, but i recommend to sell for a few bucks to a hobby-freak and buy a new one...
Nov 13, 2011 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Samsung DLP TV time, temp and lamp lights blinking... won't turn
I'm not a TV repair guy but my owners manual states that when all three LED's or lights on the front of the TV are flashing, that the lamp needs to be replaced. Might want to look into this. Good luck!
Aug 30, 2009 | Samsung DLP HL-P5663W 56" TV
Lost blue; otherwise normal; blinks 5x
If the TV standby light is blinking for five times then you may perform the steps given below:
(i) Turn off the TV then disconnect all the cables from the TV.
(ii) Next, reconnect all the cables after two minutes.
(iii) Please make sure that the power cable from the TV is directly connected to a functional wall outlet.
(iv) Next, you may try resetting the TV to the original factory settings.
Please follow the steps that are mentioned below to reset the TV to the original factory settings:
(a) Turn ON the TV.
(b) Press and hold the Power button on the Remote Control supplied with the TV, then press the Power button on the TV front panel.
(c) Release the Power button. The TV will turn itself off, then back ON again.
(d) Next, release the Reset button on the Remote control.
If the standby light still blinks then the issue may be with the projection lamp in the TV and requires replacement.
Jul 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Astar LTV-3001 and can't turn on. and I have other LTV-30MA This one have sound , no picture, can you please guive me sam help, I use to repair, Tvs. a time a go
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to if you require further assistance.
Jan 03, 2009 | Astar LTV-3001 TV
Sony Wega
Please count light flashing again. Light flash time is "0.3 Sec" and there would be pause (light Off time) for "3 Sec". Start counting after pause to next pause.
May 31, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Color variation and blinking red light on bottom of tv
The light flashing 5 times is normal at turn on as the set is monitoring current drain on the pictures tube cathodes. Any speakers near the set that have un-shielded magnets could possibly cause color issues.
Apr 16, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Please Help
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Apr 07, 2007 | Sony KV-27FV16 TV
No picture just clicking sound
with your model number manny have a defective flyback part number is 1-453-310-11
Mar 31, 2007 | Sony KV-27FV16 TV
TV solution
You may have a bad solder joint on the horizontal driver transformer or somewhere else in the set. I found this problem with this transformer several times. Stargazer
Standard (CRT) Televisions Logo
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
