FixYa.com
Tags:
Kitchen Cooktops
Generic problem for all Kitchen Cooktops
GE JCP 930 Cooktop Wiring (by 2 users)
posted by stevewhit on Nov 17, 2007
My GE cooktop consistently blows a fuse when all four burners are on. The fuses are under the counter and there are two at 20 watts each. Can I run the wiring direct and use the circuit breaker for protection?
Steve Whiteley
Comment by stevewhit, posted on Nov 18, 2007
There are fuses under the counter AND it is wired to a breaker box. I have removed the fuses and connected direct to the breaker box. Is this safe?
Comment by stevewhit, posted on Nov 19, 2007
Thanks.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by cooktop, posted on May 05, 2008
Bought a second hand Kenmore cooktop, newer than my own. The old one has fuses under the control box but this one just has 5 wires coming out the side. do I need a fuse box or can this be wired directly? It seems as though the wires have been paired (taped together) in two sets of two plus ground. The model number is C970-46049-1 but I can't seem to find any info. Tks.
Best Solution
Helpful (85)
Amigaman
Rank:Guru Guru
Rating: 88%, 288 votes
These fuses are under counter? It should be wired to breaker box. Check specs in manual but i suspect a 30 or 40 amp breaker.
Comment by Amigaman, posted on Nov 18, 2007
If these fuses are not part of cooktop, and I'm sure their not, it SHOULD be connected to breaker box directly. Again, check for proper breaker requirements.
Rating Locked! (?) stevewhit has rated this solution as Helpful
This Problem Also Relates To: GE 30 in. JGP326 Gas Cooktop GE 30 in. Profile JP350 Electric Cooktop GE 36 in. JGP628 Gas Cooktop GE 36 in. Monogram ZEU769 Electric Cooktop GE 30 in. Profile JGP979 Gas Cooktop GE 36 in. Profile JP960SCSS Electric Cooktop GE 36 in. Profile JP969 Electric Cooktop
Can you Help with these Kitchen Cooktops problems?
Baumatic B11SS Electric Cooktop
Baumatic ceamic hob won't...
Our model is only 6 months old,... Answer This...
Kitchen Cooktops
GE cooktop blows fuse
I have a GE 36" sealed... Answer This...
KitchenAid 30 in. KECC506R Electric Cooktop
HOT SURFACE LIGHTS
I have just installed a... Answer This...
Kitchen Cooktops
Igniter
All igniters failed after power... Answer This...
Jenn-Air 35 in. JEC9536 Electric Cooktop
Burner dial on Jenn-Air Model...
Burner dial on Jenn-Air Model... Answer This...
Repair Service
Find Kitchen Cooktop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
