Trying to program DISH remote...having a ridiculous time finding a workable code.Trying to program DISH remote...having a ridiculous time finding a workable code.
AnonymousApr 02, 2008
Frustrated, My AKAI LCT3701AD remote control stop working. AKAI customer service can't help....What are my options?Frustrated, My AKAI LCT3701AD remote control stop working. AKAI customer service can't help....What are my options?
You can't post conmments that contain an email address.
YOU WILL STILL NEED TO PROGRAM THE NEW REMOTE FROM THE MANUAL THAT CAME WITH THE REMOTE. NORMALLY THIER ARE TWO WAYS TO PROGRAM A REMOTE EITHER MANUALLY OR TO DO IT AUTOMATICALLY. YES THE ORIGIONAL REMOTE IS ALREADY SET UP FOR YOUR MODEL OF TV BUT WITH THAT SAID TRY TO PROGRAM IT BY BOTH PARTS OF THE MANUAL. i AM USING A 55 INCH SMART TV AND HAVE DONE THIS AND ON OTHER SMART TV'S. ALSO YOU CAN GO TO THE WEBSITE OF THE REMOTE THAT YOU PURCHASE AND LOOK FOR VIDEOS ON HOW TO SET IT UP. IF YOU NEED MORE HELP LET SOMEONE HERE KNOW. GOOD LUCK.
Hello
Three digit universal remote code for Akai TV are: 002/ 0030.
Four digit universal remote codes for Akai TV are: 0105 0002 0077 0254
Direct Code Entry
Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
I recently bought a used LCT2060 that had no remote. I figured my
comcast cable remote would work without a problem but it didn't. So 3
universal remotes later I found my solution...a radio shack
universal gamer remote. It controls up to 5 components plus your
xbox360, playstation and pc. The price on sale was a mere 12.97, not bad
if you ask me. Hope this helped. The code that worked for the Akai
was 11676. Take care...
well you say that you need to get another remote for you TV..you can buy it here at this link..http://www.amazon.com/Akai-LCT3701AD-Panel-Built-Player/dp/B000WEODRU ..ok
This place is pricey sometimes but has the best coverage of any I have found.
Akai Remotes
There are two different versions offered so a call or email might be worthwhile before buying.
The power supply failed on your LCD and will need to be replace or repair. In about 95% of the time the power supply failed due to defective capacitors, shorted diodes or open resistors.
If you need more info, you can write to [email protected]
