Question about U-Line Icemaker
My u line icemaker was freezing water but my iemaker was not working. I just installed a used icemaker, now the compressor and fan work, but no cool. compresor conections dont show leaks, compressor gets hot. Rectangular capacitor looks corroded.
  • 286 Answers
If the compressor and fan are both running and no cool then you have a sealed system issue. If you just replaced the icemaker assembly and it freezes but doesnt dump then you might have the wrong icemaker or a bad thermostat.
Posted on Jul 15, 2009
Freezer fan does not come on . Thought that replacing the DC motor would "fix" the problem. It did not. The compressor works as the freezer gets cold, but the fan never works so the refrigerator side does...
You have a bad main control board . The board in back of the refrigerator , behind an 8"X10" panel . Keep your old motor to play with . A small 9 volt battery will run it . I may have found 1 bad dc freezer fan motor in all the time i've worked on the new style G E refrig.
Aug 29, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Icemaker quit working after I cleaned the coils.
After checking the fill tube (line that fills the icemaker) to make sure it's not frozen , pour about 3/4 cup of water into the icemaker . If the icemaker dumps the water but doesn't refill , replace the water inlet valve . If the icemaker doesn't dump the ice , replace the icemaker . ALSO , make sure the fan which cools the compressor is working . Possible when cleaning the coils , a glob of lint or something , was sucked into the fan and blocked the blade from turning .
Aug 04, 2009 | Whirlpool ED5FTGX Side by Side...
Boat U-line icemaker turns on but not making ice. Don't see any water at the tray and also not cold. The water source is fine.
You wont have water until the thermostat is satisfied. If its not cooling you have another problem. Make sure your fan and compressor is running. If they are then you need a service tech to look at the sealed system. If the fan isnt running then that would turn the compressor off on overload. Then replace the fan.
Jul 13, 2009 | U-Line Icemaker
I have a u-line ULN-WH95TP-03 THAT WILL FREEZE ICE BUT WILL NOT HARVEST THE ICE. I HAVE MOVED THE THERMOSTAT AS WARM AS IT WILL GO AND IT STILL WILL NOT HARVEST. IF I MANUALLY MOVE THE TIMER JUST A LITTLE...
Your thermostat is what advances your icemaker. You have 3 wires. When it calls for freeze then yellow(2) and blue/black(3) is closed. When that is satisfied the compressor and fan cycles off then the yellow(2) and red(1) is closed. This calls for the icemaker to advance. Red goes to icemaker, yellow is common, and blu/black is for the fan and compressor.
Hope this helps you. I would replace the thermostat
Jul 13, 2009 | U-Line Refrigerator Ice Maker
Have a bi95 water not going throught inlet valve,hose is clear to freezing tray. took valve apart did not see any obstruction. any suggestions? thanks mike55
The valve assembly for U-lines shouldnt be taken apart. Now the first thing is to advance the icemaker. Remove the cover off the icemaker head. (pry and pull at the same time) use a 5/16 nutdriver or socket on the small gear. Turn it counter clockwise. Whent he ejector blade reaches 1 or 2 oclock it should take off by itself. When the ejector blade reaches 10 oclock then it calls for water.
(ejector blade is the fingers that push the ice out)
How a bi 95 works is the thermostat need to be satisfied first. Then it advances the icemaker. Turn it to the warmest setting. If its set too cold then it would run and never be satisfied.(warmer the setting the more ice it makes) Everytime the compressor cycles off the icemaker should be advancing. If not then the thermostat could be stuck in the freeze mode.
T-stat Terminals 2 is yellow(common)
3 is blue/black (fan & compressor)
1 is red (icemaker)
2&3 closed freeze cycle
2&1 closed harvest mode
Jul 10, 2009 | U-Line Icemaker
Give-me plis a wiring digram manual of the Ice Maker U-Line BI-95
Your going to call U-line and ask for it. 800-779-2547. Now what are you trying to do? I can give you the wires on the thermostat. Terminal 1 is red(icemaker) Terminal 2 is yellow(common) Terminal 3 is blue/black(compressor and cond fan motor) When yellow and blue or black are closed this will run the compressor and fan.Thermostat is satisfied then the red and yellow are closed and it advances the icemaker. Ejector blade at the 12 oclock calls for freeze cycle. at 2 calls for heater to come on(inside icamaker) at 10 oclock it trios the water switch and calls for water.Then back at 12 oclock calls for freeze cycle. Temps should be 10-15 degrees in the bucket. Warmer the setting the more ice it makes.
Jun 30, 2009 | U-Line BI-95
Makes ice for three days, water drips to fan, freezing up,
there is a device like a switch that makes the icemaker stops the solenoid valve of the water intake, u should check that switch...
Mar 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
U-LINE BCM95 NOT CYCLING
These units take a full cycle to get to the fill cycle, so you won't get ice on the first cyle unless you manually fill the tray when you first power it on. You may have some air in the water line and need to cycle a few times to fully bleed the air out. Also check the water inlet for debris in the filter screen using a small brass brush, then bleed out air -with water on- while tightening back hose connection avoiding need to bleed while cycling. Lyle
Nov 11, 2008 | U-Line Icemaker
Compressor is extremely hot
Compressor will be hot to the touch. You stated the fan was replaced and then said the fan is not cooling. If you replaced the fan and it is now operating, reinstall the panel you removed to install the fan motor. That panel determines proper air circulation to cool the system.
Jun 14, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
U-Line Icemaker Logo
170 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
