Question about Cabela's Grilling
My cabela smoker is burning orange flames and I suspect the propane/to air ratio is off, how do i correct that?
SOURCE: smoky mountain series propane smoker
Solution #1 is the answer -- replace the regulator. The problem is that the regulator is stuck closed. You can either replace it, or pop the little metal cap on the top off and adjust it. (Use a large philips screwdriver). Do a full turn counter-clockwise, and then 3/4 of a turn clockwise.
Posted on Apr 06, 2008
TheMobilian
  • 8220 Answers
SOURCE: King kooker will not burn a blue flame, only a big yellow sooty
You may need to resize the orifice, sounds to me like it is too big. If you have an adjustable orifice try tightening it down a quarter turn at a time till that flame turn pretty. Leave that shutter wide open till you start getting a blue flame. Make sure you have no cob webs blocking the orifice.Blow out and remove all rust from the burner.
Posted on Mar 06, 2009
  • 10865 Answers
SOURCE: Side burner on propane gas grill burns with orange
here is a link to a page that shows what the colors of the flame should look like and what causes the orange instead of the blue flame. http://www.appliance411.com/faq/gas_range_flames.shtml
I would begin by checking to be sure you do not have a spider or a cob web in the burner partially blocking the gas or the air intake.
Posted on May 12, 2009
  • 36 Answers
SOURCE: Propane gas flame is not hot. Do I adjust the air
Here is something to try if it is LP Gas:
Here is a Tip to fix a grill that not getting hot:
1. Turn the gas valve knob off. then close LP tank valve knob.
2. Unscrew the plastic hose coupling knob from the LP tank. You may hear a slight "hissing" sound as pressure is released this is normal.
3.Wait a minute then screw the coupling knob back on to LP Tank.
4.With lid open.slowly open LP tank valve.
5.Relight the grill the proper way by turning gas valve knob to ON position while turning the igniter knob at the same time.
6.After you are sure the grill is lit preheat the grill for 30 minutes.
This was called purging the line or releasing the air out of the line.
Another thing your orifice could be clogged with spiders or dirt. If it is LP gas check to make sure your hose is not kinked.
Posted on Mar 25, 2010
  • 494 Answers
SOURCE: Have a large mobile propane grill with burner problems
Ok, here is a check list for your most common gas grill lighting problems:
1) Check your tank. Is it empty or nearly empty? The tare weight (T.W.) of your cylinder is stamped on the collar. This is the weight of your empty cylinder, usually around 18 lbs. Weigh it on your bathroom scale2_bing.gif. Propane weighs 4.25 lbs/gal. If it weighs around 20 lbs or less - Refill it. If not, go to #2.
2) Make sure you didn't turn the gas tank valve on too fast. Some gas hoses have a built-in excess flow valve that stops the flow of gas to a trickle if opened too fast. Close the tank valve and let sit for a few minutes. Or just disconnect it and reconnect it. Turn the tank valve very slowly and then try lighting it again. If it doesn't help, go to #3.
3) Is the igniter sparking? Some are battery2_bing.gif powered-check the battery or replace it. If you have a standard push button piezzo igniter or a rotary style2_bing.gif igniter, check for spark. Can you hear or see the spark? It's hard to see the spark in bright daylight. It's easier to view the spark at dusk or dawn. It should spark an "arc" at the burner. If not, adjust it if necessary. The igniter wire may have a short, causing the spark to arc somewhere else along the wire and not at the burner. Replace igniter wire. It's also possible the igniter tip where it sparks has a cracked or broken porcelain portion of the igniter, causing the spark to not arc at the tip where it's supposed to. Replace the igniter piece. If not, go to #4.
4) You may have a rusted, clogged or damaged burner or venturi tube. With a flashlight, check for spider webs, wasp nests or dirt (mud) dauber nests in the opening of the venturi tube where it connects at each gas valve orifice. Clean it out manually or blow it out with air compressor. Make sure the air adjustment opening (on the end of the burner's venturi tube) has not been changed. If it's closed too much, it will be difficult to light and cause lazy yellow flames. If it's not clogged, the burner may just be old and rusted and the burner holes are not allowing very much gas through anymore. It's also possible the burner has rusted so bad, the burner holes have been enlarged, it is falling apart or has cracks along the burner seams. If so, replace the burner(s) immediately. It is unsafe to use. Your local propane co can usually order the parts you need and some will even do the work, if you are uncomfortable doing it yourself. Bring with you the Make, Model and Serial number of the grill, so they can order the correct parts for your specific grill. Also specify whether it's natural gas2_bing.gif or propane.
5) If none of these resolve the issues you are having, it is also possible you have a faulty or defective regulator, which may mean replacement. If the pressure still seems too low and none of the above has helped, and you have a silver/gray regulator; many have an adjustment screw on the top center of the diaphragm. Remove the outer cap and turn the inside screw clockwise in 1/4 turns to increase the pressure until the desired flame size is accomplished. Flames should be as blue as possible, but will burn orange if there is food or drippings on it. Yellow flames are not good, and will soot up everything and not cook as hot as blue flames do. Yellow flames could mean you do not have the right air shutter adjustment, clogged burners, or possibly defective burners, as mentioned above in #4.
6) Also make sure you have the hose connection tightened snugly to the propane tank valve to ensure the inner valve seat is fully depressed allowing gas to exit fully without any restriction. The black plastic female fitting should be hand tightened only. Older versions that use a left-hand male brass POL valve, requires a 7/8 open end wrench or adjustable wrench to tighten.
Hope this helps! Good luck in your trouble shooting! Douglas
Posted on May 20, 2010
What color should the flame be on a propane fireplace insert---blue or yellow?
clean burn gas is a blue flame
it is achieved by using the correct jet size for the gas in use and by adjusting the air shroud around the jet opening
if you converted from natural gas to LPG and didn't change the jet size that is one reason
next there is a tin type shroud around the jet area that can be moved back or forward over the big hole that lets air to mix with the gas at the jet
the position of that shroud adjusts the air to gas ratio
If you are not sure of what I am talking about , talk with a gas fitter or have them do the job
Oct 10, 2016 | Napoleon Heating & Cooling
LOOKING FO A NATURAL GAS TO PROPANE CONVERSION KIT.
the change over requires different jets and adjustment of the air shroud around the chamber
there is a process to adjust to get correct flame burn and it is best done by an accredited gas fitter
the jets will be available from any BBQ or out door cooking specialist/ gas shop
Apr 08, 2016 | Grilling
My daughters 2400 kerosene monitor will light, burn for about 2 to 3 minutes and then go out. The flame starts as a nice blue then goes to orange then looks red and goes out. Please help!
Susan, I suspect you have air in the lines, you will probably have to bleed line at pump. 2nd link explains how to.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://monitorproducts.com/wp-content/uploads/M2400OwnersManual.pdf
https://ca.answers.yahoo.com/question/index?qid=20070208183218AAEiYdr
monitor heater repair help
Thread Monitor 2400 e13 error code
Mar 05, 2016 | Cars & Trucks
Flame is just orange
there might be a cloq in line or burners like spider webs
.the air and gas is not the right ratio that is why flame is not blue
May 27, 2014 | Fiesta Blue Ember Gas Grill
Flame burning too orange
You need to get a Plumber or Appliance Tech to come out immediately and check the fuel to air ratio. You are not burning your fuel at the proper mixture. A blue flame is good, yellow-orange is bad.
Normally this is because the burner area is dirty or the pressure regulator may be set too high/low. The black marks are a sure sign that your ratio is too rich and it's just going to build up more soot and become unhealthy and dangerous.
http://inspectapedia.com/plumbing/Gas_Flame_Noise_Defects.htm
Don't wait...
Mar 27, 2014 | Water Heaters
Flame does not burn blue -- it is more yellow and sooty
From what you described, the burner needs to be removed and cleaned and the air shutter adjustment needs to be readjusted. After cleaning and replacing the burner, you can light the unit and then start adjusting the air shutter, until the flames are blue with yellow or orange tips.
Hope this helped you.
Jun 30, 2011 | Camp Chef Gas Smoker
Why does my gas smoker leave a greasy black coating on all the meat?
Hi, The flame is too high and not burning correctly...
You problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Sep 18, 2010 | Char-Broil 7000 Quick Set Gas Grill
Side burner on propane gas grill burns with orange flame ratheer than blue
May 12, 2009 | Weber Gas Go-Anywhere Grill
Why is my stove causing a thick coat of soot to buildup on my pots?
you have to adjust the air intake holes at the valves. this will give you a blue flame.
Aug 16, 2008 | Coleman Propane Grill Stove 9921-700
Grilling Logo
59 people viewed this question
Top Cabela's Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Cabela's Grilling Expert? Answer questions, earn points and help others
