Question about Hotpoint Aquarius WMA42 Front Load Washer
Where ecxactly do you put washing powder and stasoft
I tried using it and it did not use the washing powder i had put in one of the compartments.
  • Hotpoint Master
  • 3,463 Answers
Washing powder should go in the right hand side compartment, if it is not going down, then check that water is coming into washer.
Conditioner should go in the smallest of the compartments.
Please rate my solution.
Thanks.
Posted on Jul 15, 2009
There is caked washing powder let over in the tray after every wash and the clothes are not being washed properly. How do I fix this?
read the user manual for the right section to use
if you do not have a user manual then go google and type in ---user manual for ( make and model of machine ) and download a pdf version
personally washing detergent powder causes more problems that what it is worth
change over to liquid detergents
Oct 28, 2015 | Washing Machines
My washing machine won't use soap from the drawer
are you useing the right draw for main wash try putting on a wash and open the draw there should not be any water leaking if you do this and look in the compartment that you put the powder in and see if the water is going into the compartment that you use and see which compartment is filling thats the one to put the powder in
Nov 14, 2011 | Washing Machines
Where does the laundry powder go on the left or right compartment?
I am going to presume u have a front loading machine in your home,, put the powder in the left hand compartment, as the right is for use of a fabric softner if u wish to do so :)
Apr 17, 2011 | Bosch Washing Machines
In which of the 3 compartments should I put a liquid soap?
The small centre rack is used for whitening agent! The extreme right for the pre wash.
For delicates you have to use the same rack and finish the load. See to it there are no remains of powder, if your load is delicate material.
Apr 02, 2010 | Siemens WD61392GB Front Load Washer /...
LAUNDRY SMELLS BAD
take out powder compartment its more likely its gone all black....also in side of the machine... get white vinager clean all inside and powder capartment .... put 2 ltrs of white vinager in drum place powder unit back were it should be..... turn machine on with no cloths in on full heat wash (boil wash)....wash through again with powder when finished ....twis before putting any cloths in ..there you have it ...oh check pump filter befor all this :)
Dec 30, 2009 | Bosch WFL 2063 Front Load Washer
Do I put powder detergent in the same place I put Liquid detergent?
Detergent compartment
Add liquid or powdered detergent to this compartment for your
wash cycle. The detergent separator must always be in place,
either in the front or back position.
 Do not fill beyond the “MAX” level.
 Liquid or powdered color-safe bleach may be added to the
Main Wash compartment along with the same type of
detergent, liquid or powdered.
 Liquid detergent: Put the SEPARATOR in the front position,
between the guides, as shown as shown by Position 1 below.
There will be no gap between the bottom of the wash cycle detergent
compartment and the bottom of the separator.
Powdered detergent:
Put the SEPARATOR in the back
position, behind the guides as shown by Position 1 below. There will be
a gap between the bottom of the wash cycle detergent
NOTE: The separator will be in the POWDER (back) position
when shipped from the factory.
Nov 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Where do i put washing powder in hotpoint aquarius 1000 three compartments in drawer what solutions go in what compartment
with experience, put powder in the first, softner in the middle second, pre wash in the third, but with that model i find its always best to use a liquid or gel direct into the machine, it makes the life of the machine last longer, also stops any build up residue
Jul 18, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Bosch axxis washing machine detergent symbols
There are usually 3 compartments in the drawer, the smallest is for using fabric conditioner, the largest is where you put the powder or detergent in, the middle size one you do not put anything in, as it is where the cold water comes in for rinsing.
Plz rate my solution.
Thanks.
Jan 26, 2009 | Bosch Logixx WFT 2806 Front Load...
Soap powder remains in the soap compartment
Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
Plz rate this solution.
thanks.
Dec 28, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
698 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
