Question about ASUS Intel 810E Chipset CUWE-RM (CUWE-RM/WOA) Motherboard
Boot Problem Sir I have an P-III 733 MHz 810 Frontech motherboard and 20 gb HDD. I am trying to install win xp thru boot cd. Initially it is started and install all the necessary files from cd to HDD. After that The machine restarted and windows flag come.From there it is not going further. Monitor is black but green light in monitors start blinking but CPU is on. I cant understand why it can not boot from HDD while installing. Is it a mother board problem or my HDD problem. Please guide.
    President:
  • 1,383 Answers
When it restart press F8 buttton thenenter in enable vga mode then if u able to see screen then no problem .
But if still face problem try to dleete all partition and create new partition then format c then check .
Posted on Jul 15, 2009
Dell bootmgr is missing
Most likely cause is that the boot order in the BIOS is set up for the HDD first. When turning on the unit, press the key needed to enter setup. Once in setup, search thru the menus for the boot order. Choose the CD drive as the first boot device, then the hard drive as second. Save and exit the setup. When rebooting, ensure the WIN XP CD is in the drive. When the screen says, "press any key to boot from CD", press a key and the WIN XO CD should take over and start the install. Once WIN XP starts installing, follow directions. On each restart after that, DO NOT press the key to boot from CD. WIN XP setup will handle everything until the reinstall is complete. After you are done, you may choose to go back to setup and change the boot order back, but it is not really necessary. The only time you will get the "press and key to boot from CD" message is when there is a bootable CD/DVD installed in the drive. Otherwise, it overlooks it and goes to the next boot device (HDD).
Sep 07, 2014 | Dell Inspiron 2600 Notebook
How to boot via CD-ROM in IBM PC 300
my IBM flat desktop is not booting from CD ROM, Please help me.
Jun 18, 2009 | IBM 300PL (PC 300 PL 733) PC Desktop
I am unable to install win Xp. when trying to boot from a cd to install fresh win xp ser. 2. system reboot after copying few installation files. The Bios set up shows the Sata Hard Drive but unable to load...
your HDD may be bad. I have had a number of HDD that appear fine in the BIOS but won't format either via the install disk or separately via a Linux boot disc.(You can somtimes hear them clicking on and off [seeking])
If you are mad keen on the drive, then D/L 'Hirens Boot Disc' and boot into the DOS mode (it also has a Mini XP mode).and use the HDD format utlity 'killdisk'. This will remove anything on the drive, format it and set it up ready for a fresh install.
If Hirens Boot Disk can't see the SATA drive then its stuffed.. for sure..
Apr 16, 2009 | ASUS P5LD2-VM Motherboard
Sound Card Driver needed for Win XP runing on Intel 810 Board
hi im josh in cebu phils. it is very simple frnd. you try to install windoxs xp sp2 or sp3 so that you will not need to install driver for sound. or just get an update of your xp professional. good luck!
Feb 17, 2009 | ASUS Intel 810 Chipset P3W Motherboard
Boot problem with Dell Optiplex GX150
To reinstall Xp from the CD you need to press F2 and go into the BIOS then select the boot order configuration and make the CD the first boot device and the hard disk the second boot device.
After installing XP, if you wish you can go back into the BIOS and change the boot order to boot from the hard disk first.
Dec 13, 2008 | Dell System Board for Optiplex GX 150,...
I have a P III with 40 GB HDD and 384 MB RAM My motherboard is a Intel chipset - 6B810ECD (2M) -B0 I am not able to boot up the OS (xp) . It boots upto the Bios display and doesn't gets past that
Please try to login through the safe mode by press F8 key at booting time. and if doesn't get success than try to reinstall windows xp without sp2. Please some p3 system doesn't support win xp with sp2.This might definately solve your problem.Feel free to revert. Rest assured
Dec 04, 2008 | Computers & Internet
Dual boot problem
first install win98(dont re boot for xp installtion),  while running 98, insert cd of xp and install xp from there.
Nov 18, 2008 | Biostar P4M80-M4 Motherboard
Problems Installing my 160 GB Seagate SATA HDD
you need to go in bios and set sata to legacy for no F6 driver. if its on native it need a driver from floppy on xp cd boot . if its not detected in windowws as a slave. u need to run diskmgmt.msc and fin the unalocated drive and create part then format it ntfs
Nov 05, 2007 | Asrock K8Upgrade-VM800 Motherboard
ASUS Intel 810E Chipset CUWE-RM (CUWE-RM/WOA) Motherboard Logo
93 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
