Question about HP OmniBook 6000 Notebook
When i switch it on i can bearly make out any of the icons on the screen have tried all the usual but no joy also the battery light is a constant amber
  • 24 Answers
Try to go into the bios and try turning up the brightness there.
Posted on Jul 15, 2009
Hp compaq 7620s wont start ( constant blinking blue light )
The adapter output appears correct, the batteries often work in that voltage range. But the problem you have is the motherboard, the HP line has constant trouble with the main board, only option is board replacement.
May 12, 2012 | Computers & Internet
2001 daewoo lanos immobiliser problem car wont start. entered radio security code. immobiliser dash light is still on.
Radio code has no bearing on the immobiliser at all.
Normally it is down to the key not recognised. Are you using the same / usual key as before? If not then try original or another key as it may be the transponder in the key you are using.
If same key or no joy then remove the lower Black plastic steering cowls on the column (normally 3 or 4 screws) you will expose the barrell assy, on the end of this you'll see the transponder pick up ring. Disconnect from loom, apply silicone grease to pins and reconnect then try starting.
If still no joy, disconnect positive terminal off the battery, touch the lead to an earth point for 2 to 3 seconds to defuse and reset ECU, reconnect and try again.
If still noy joy you will need a garage as special reading equipment is required.
Regards
Lloyd
Aug 21, 2010 | 2001 Daewoo Lanos
Black screen
take a flashlight and look at the LCD screen and see if there is a faint picture to it. if there is, its a bad backlight.
if no picture you can hook an external monitor to it and switch the mon out to the external. usually this requires a FN key + monitor select function key pressed at the same time.
Aug 06, 2009 | UltraLast FOR HP PAVILION ZE 4000/5000...
Nokia 5800 Lights on but no screen
change your battery....battery problem......
Jul 03, 2009 | Nokia 5800 XpressMusic Smartphone
Laptop failed to light up after being switched on
  • MAY BE THE BATTERY IS GETTING WEAK
  • ENSURE THAT YOU DIDNT OVERCHARGE THE BATTERY.
  • IT WILL MAKE THE CELL LIQUID TO GET OVERCHARGED MAKING THE ELECTRON FLOW TO GET SLOW.
Apr 29, 2009 | Computers & Internet
Acer won't boot up
when any computer posts/boots up.
it goes through a sequence of initialising things before booting.
i,ve been repairing computers for around 12-15 years.
1st i,d try removing the ram ( memory ) usually underneath the laptop, behind a screw cover. Or ocassionally under the keyboard.
if 2 sticks of ram are installed, remove the battery. and 1 stick of Ram. put battery on and try to boot. if no joy with that try the other stick of ram. and replace battery-Re-boot.
If this works you have 1 stick of faulty ram or faulty ram slot on motherboard. Failing this. I suspect that the CPU has overheated, and therefore a replacement Processor should solve the problem.
Thankyou for using fixya.
Mike @ compurepair.
Apr 20, 2009 | Acer Aspire 5315 Notebook
Archos 605wifi not switching on
Hi, my Archos 605 160GB is doing the same, Sorry to say the battery has gone.
2 options
1. Back to Archos
2. Replace the battery yourself I ordered mine from HK from the web site BatteryUpgrade. co. uk for about £24 - If you search on Utube there is a video showing you how to change the battery on smaller 605's
Jan 09, 2009 | Archos 605 WiFi Digital Media Player
My indicators and battery icon
Is this the battery indicator in the car? More info needed here.
Secondly, is this the power indicator lights on an amplifier that won't go off after being shut down? If it is, make sure the remote turn on lead is hooked to a switched source and not a constant 12v one.
Aug 01, 2008 | Car Audio & Video
HP OmniBook 6000 Notebook Logo
35 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
