How to back flush heater core 2007 grand prix
drain coolant system locate heater cores hoses going through firewall you need to buy the radiator flush kit at any auto parts stores. remove heater cores hoses from one end or buy extra long heater hoses same size as heater core hoses in vechicle at auto parts store use the flush kit when you flush through one of the heater core hoses let the other hose drain in a drain pan when you use home garden hose use low water pressure dont use garden hose to the max or you will rupture heater core. your best bet let radiator shop flush whole coolant system. because heater cores hoses are in a tight spot.make sure engine off if you just going to flush out heater core only .after flushing heater core good time to replace heater core hoses.if job too hard or complicated let radiator shop flush out radiator the engine block and heater core because if radiator stopped up or engine block stopped up the gunk and rust will reenter plug up heater core.if you tight on money you can flush out your own radiator.drain out radiator using large drain pan. remove top radiator hose and remove bottom radiator hoses connect to water pump.use garden hose with flush kit part with water pressure not too high put garden hose to top radiator hose run water until clear water run out bottom radiator hose in drain pan,the flush out engine block remove thermostat.if you had another spare thermostat housing with RTV SILICONE SEALANT THAT HAS SET UP INSTALL THERMOSTAT HOUSING BACK TO ENGINE WITHOUT THERMOSTAT FLUSH OUT THE ENGINE BLOCK, WHEN DONE INSTALL NEW THERMOSTAT THEN INSTALL ORIGINAL THERMOSTAT HOUSING WITH NEW ORING WHICH YOU BUY AT DEALERSHIP.IF ALL SOUND COMPLICATED LET RADIATOR SHOP FLUSH OUT COOLANT SYSTEM.
