Blue Lines and freeze with lines. Startup problems
Startup with lines. otherwise it doesn't start. When it starts right than freezes every 30 min.
  • 24 Answers
Something is going wrong with your softare/ run a virus scan and if it still has problems and you are running xp or vista try doing a system restore to about a date of a week before you started having this problem. last resort is to do a full reload of the OS.
Posted on Jul 15, 2009
I a 16 user L230. my problem is that the terminals freezes. At logon, they are fine but they start to freeze after about 20mins after i switch the system on. its not particular stations athat freezes but...
The terminals never actually freeze as they are getting desktop sessions from the host. What can happen is the desktop session can lock up and thus any corresponding user input doesn't happen due to the session being locked up. Next time this happens, see if the server/host is responsive. Assuming it is, launch Performance Monitor(Provided as part of the Windows OS) by going to Start ' Run ' Perfmon. Monitor your CPU performance. See what's taking all the CPU resources. It's not uncommon to see unncessary programs running, i.e. jusched.exe (Java Scheduler update), qttask.exe (Quick Time updater), etc. All these programs and other unnecessary programs run at startup and run for EVERY single user so in your case, the jusched.exe runs 16 times and can take valuable system resources. Disable these by going to Start ' Run ' msconfig, press enter, the farthest tab on the right labled STARTUP is where you can disable these programs. After deselecting the ones you don't need, reboot the host and tell the dialog box to NEVER tell you again so that it doesn't alarm you're users that you've messed with the startup config. Lastly, don't overlook that fact that you need 1GB NIC and backbone to the server, each device can take up to 15MB/s of network bandwidth.
Jul 05, 2011 | NComputing L230 Network Terminal
Freezes after few minutes
It is also important to remove the suspicious applications and programs in the computer to avoid Windows freezing. In this type of infection not only your Windows registry gets corrupted and needs massive repair but also there is virus based penetration in the Windows set up. In this situation it is recommended to conduct a virus scan as well.However, if your Windows freezes up, the best solution is to repair the computer registry.use registry cleaner reg in out
Sep 11, 2010 | IBM ThinkPad T40 2373 Notebook
Won't start in cold. It's not the battery. The starter has been replaced, but I'm not sure if the part was genuine.
If the temperture is below 30 deg. it could be you have water in the fuel lines and freezes and stops the fuel from getting to the engine. use gas line anti freeze.
Apr 28, 2010 | 1998 Saturn SL
Dell inspiron 6400 freeze after startup
do a system restore before it started doing it.
Nov 08, 2009 | Dell Inspiron 6400 Notebook
Froze. very slow. very hot
Sounds to me like the cpu fan,has died and the cpu is overheating causing the freeze, the slow running, and the excessive heat. the cpu is probably fried.
Jul 12, 2009 | HP Pavilion dv6000z Notebook
Occasional freeze after startup
If it didn't make it through scan disk it is most likely the hard drive.
May 26, 2009 | HP Compaq nc6220 Notebook
Bottom of screen flickers, and eventually the screen 'freezes'
they have problem lines in tv screen harizontall lines how i can fixed in HDTV prima 29inch.2008 model .give me ANSWER .
Jan 17, 2009 | Prima CV2011 TV
Home pc
hello,
try this,
click on start then run, type msconfig in command box,
system configuration window should show up. click on tab called startup. click disable all, then apply, then click ok, it should ask if u want to restart. please restart the computer.
what will it do? it will disable all startup applications.
if this resolves the issue, then you would know its one of the startup application causing your computer to freeze it.
also right click on bottom bar, then click task manager.
click on tab called processor.
average processor is 25-30.
in my laptop i have only 19 processor runnning.
if you have alot of processor running that definitly cause PC to slow/freeze.
hope this information help you
Dec 22, 2007 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
Computers & Internet Logo
169 people viewed this question
David Payne
David Payne
