Question about Whirlpool AWM6120 Front Load Washer
Service light comes on a minute or two into the cycle and cycle does not complete.
    Sergeant:
  • 270 Answers
Send it to service center
Posted on Jul 15, 2009
I replaced the alternator on my 1999 Audi A6 with 2.8 engine. Now the check engine light is on. Was not on prior to the repairn. How do I correct?
Instructions on How to Turn Off The Check Engine Light:
Step 1. If not using a scan tool, locate your vehicle's battery. Disconnect the 12v positive cable (red wire) from battery terminal (+). Leave it disconnect for 5 minutes. While the battery is disconnected, cycle the ignition switch to ON position 3 times. If using a scan tool to turn off the check engine light, follow manufacturers directions. You will need to find your vehicle's OBD II Data Link Connecter (DLC) and connect your scan tool to the DLC, then follow the steps indicated on your scan tool or scan tool manual.
Step 2. Insure ignition switch is OFF. Reconnect the battery 12v positive cable (red wire) to battery terminal (+).
Step 3. Cycle ignition switch to ON position and wait 1 minute, then start your vehicle. Check Engine Light or Service Engine Soon Light should be reset and turned OFF.
Step 4. Drive your vehicle for one week under normal driving conditions. During this period the emissions computer is gathering data and re-learning your vehicle's emissions components and systems. The emissions computer OBDII (on-board diagnostics) system must complete at least one drive cycle (in some cases two or three). A drive cycle is a sequence of internal tests which the emissions computer runs while your vehicle is being driven. This insures all emissions systems are functioning properly. Proper "readiness flags" are set as the computer completes it's cycles. Test cycles are unique to a vehicle. Certain cycles run under very strict parameters, and may require extended driving time to trigger on. Cycle data and readiness flag information is available through your dealership's service department. The data vary widely.
Sep 15, 2014 | 1999 Audi A6
Tip
Dishwasher Clean Light Flashing or Blinking Seven Times
Whirlpool and Whirlpool-made Kenmore Dishwashers are equipped with a fault detection feature within the control software to help the user and most especially the technician diagnose a problem when it occurs. One of the common faults is indicated by a pattern of seven (7) flashes or blinks made by the Clean light indicator. It occurs when the control detects a failure in heating up the water to at least two (2) degrees Fahrenheit above the initial temperature during the first eight (8) minutes of the cycle.
The control monitors the temperature of the water both at the start and at the end the first 8 minutes of the cycle. It will not allow the machine to advance to the next cycle if the necessary end temperature of the water is not reached; instead, it will shut down the machine and will not allow the user to operate it unless the error is cleared. But the error will continue to appear until the problem is addressed.
The error can be cleared by pressing the Heated Dry button then the Normal button in sequence twice; that is, Heated Dry, Normal, Heated Dry, Normal. The user will then be able to restart the cycle but the error will eventually come up again and will not get the cycle completely done.
In order to complete the cycle, make sure water is being fed properly to the machine, the washer impeller is not stiff or stuck, and the float bulb is not stuck in the up or full position. Once all of these are ensured, preheat the water to at least 160 degrees or cool it down to below 62 degrees Fahrenheit before feeding it into the machine. These extreme temperatures will bypass the water temperature detection step and automatically proceed to the next step and complete the cycle.
The technique described above is not intended to address the problem which can be a failure of the heating circuit, water system, pump,or wash impeller. But rather to bypass the water temperature detection step and complete the cycle. The user is advised to determine the reason why the water is not able to heat up. Service of a qualified appliance technician is recommended if the user is not technically inclined to perform the necessary troubleshooting and repair. Disconnect power to the machine prior to servicing to avoid the risk of electric shock that may result to physical injury, disability, or even death.
on Apr 26, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Service number kuds301xbl2
I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
Apr 28, 2013 | Maytag MDBH975AWS Stainless Steel...
How do i turn off my check engine light on my f150 '02
It will have to be done with a code reader for obd2 system.
Apr 28, 2010 | 2002 Ford F150 Regular Cab
Will Not Run
I had the exact same problem. The tech came by and suggested to run the diagnostic cycle to clear up the error. Nice guy didn't charge for the time. He said Whrilpool has a poor software design.
Problem - LED blinks 7 times when the temperature doesn't come up to the degree F required for the wash. This may happen if someone took a shower minutes before starting the dishwasher.
The Tech said, Whirlpool should have allowed a straight forward reset by the customer (instead of disabling the machine for a tech to come by and fix the minor issue).
Here is the solution.
Solution - (is pretty much the same to clear up the other software glitches as well)
Try "resetting" the control board by running the diagnostic cycle. The cycle completes in 15 minutes.
The details are in the service manual. The manual can be found hidden behind the tow plate (at the very bottom front of the washer).
The diagnostic cycle may tell you the problem. It also helps clear up some of the software gltiches.
It is easy to run the diagnostic cycle.
Just the buttons in the following sequence. The sequence should be complete within 6 sec.
heated dry -> Normal -> heated dry -> Normal
This will trigger diagnostic cycle of 19 intervals. Pay special attention to the intervals 18, 17, 9, 6, 4.
Interval 18 - displays your controller module number (should be letter 'd' followed by number 0 or 1 or 2 or something. Note that down for future reference.
Interval 17 displays 'software generation number' Note that down for future reference.
Then wait until you reach interval 9.  --- clean LED turns on - then an open or shorted thermister is detected.
-- Sanitized LED turns on - then the washer detected greater than 100 deg F temperature
Interval 7
-- Soaking/sensing LED should NOT come on (unless food soil is present).
Interval 4 -- Soaking/sensing LED should come on
Let the cycle complete and then try running the normal wash. Hopefully the possible glitches are cleared by now and you should have no problem.
If this doesn't work, time to call the expert tech.
Jan 05, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool gold dishwasher gets stuck at 53 minutes left for an hour
Interval 7
Nov 08, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Flat top Accubake self clean 24 inch
Of course - Empty the oven and clear off around it.
The AUTO-CLEAN cycle time is adjustable, from 2 hours
30 minutes and 4 hours 30 minutes in 15-minute increments.
Suggested clean times are 2 hours 30 minutes for light soil and
4 hours 30 minutes for heavy soil. The last 30 minutes of the
cycle is for cool down.
To Self-Clean Using AUTO-CLEAN
1. Press AUTO-CLEAN.
2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
desired self-clean cycle time.
3. Press START.
The oven door will automatically lock. The “DOOR LOCKED”
and “CLEAN” indicator lights will be displayed. The time
remaining will also be displayed.
4. When the self-clean cycle is complete and the oven cools,
the “DOOR LOCKED” and “CLEAN” indicator lights will turn
off.
5. Once the oven is completely cooled, remove ash with a damp
cloth.
To Delay Start Self-Clean Using AUTO-CLEAN
2. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired self-clean cycle time.
3. Press START TIME.
4. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired start time.
5. Press START.
The oven door will automatically lock. “DOOR LOCKED” and
6. When the self-clean cycle is complete and the oven cools,
off.
7. Once the oven is completely cooled, remove ash with a damp
cloth.
Owner, Warranty, Installation and Parts manuals are here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
Sometimes search links don't work when copied.
Here is the direct link to the Use and Care Guide:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
Page 16 has the above instructions.
God Bless!
-Ptochos
Jun 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
Whirlpool AWM6120 Front Load Washer Logo
120 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
