on your motherboard you will find these connections (each motherboard varies) just put the corresponding cables to the pins. it will tell you which is which on the end of the cable.
Its quite a simple case, just try to get the name of the motherboard, and its model number, then search for its manual online if you dont have the motherboard manual, or just post the Motherboard name and its model number on fixya and let the experts find it for you. Hope this helps. Goodluck!
There must be something written on the motherboard like res sw(for reset), hdd LED(for harddisk), pw sw(for power button), pwr_LED (for power LED)etc.Mostly it is written near the front panel jumpers.
Try to locate these type of keywords on the board and then place the front panel LEDs accordingly. There are separate LEDs for different operations.
I have a promax x chip and i want to fit it to my 2008 citroen c5 1.6 diesel. I am not sure of the...
(More)
I have a promax x chip and i want to fit it to my 2008 citroen c5 1.6 diesel. I am not sure of the maf sensor and which wires to connect to. There is also a wire for the o2 sensor? Regards Terry
Hi, i would buy NBA 2k10 for PC I checked my laptop specs and it passes the system requirement but i...
(More)
Hi, i would buy NBA 2k10 for PC I checked my laptop specs and it passes the system requirement but i got a question: It says the Grpahics card for Nvidia needs to be 6600 or better and minimum memory of the grpahic card is 128mb, my graphic card is Nvidia 8200M G (Integrated) and graphic card memory is 128MB, so will my grpahic card work and will i be able to play NBA 2k10? some people say Nvidia 8200MG (Integrated) cant play some games, is NBA 2k10 one of them, and if i can play i shld put it in high,medium or low settings? Thanks
