Dvd disk placed in tray - will not play - cannot open door to get it out. data on dvd may be faulty - but I cannot see how that would stop the door from functioning
  • 1 more comment
  • JOHN DOORNKAMP Jul 15, 2009
    nothing
    pressing eject button when dvd in off state causes dvd to come on.
    tried eske's suggestions.
    Nothing
    pressing the eject button is turning on the dvd so it is impossible to treat on/off button and eject button as two separate operations.
    very helpful - worked first time
    many thanks
  • 198 Answers
It's probably stuck in a frozen state. Mine used to do this until I replaced it.
The best thing to do is unplug the DVD player, wait a few seconds and plug it back in.
Don't press the power button, instead, hit the eject button right away.
Some DVD players do this from time to time. Old or new.
If this is directly attached to your PTV, write your picture and audio settings down so you don't need to reconfigure your settings in the hard way.
Let me know if this helped.
Posted on Jul 15, 2009
  • 13,433 Answers
Try turning it off, then turn it on and at the same time repeatedly press on the eject button.
If that doesn't open the tray try again, this time hold down the eject button while turning it on.
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
A disk is stuck in my Harmon Kardon player. The door will open and close and I can see the disk but cant' get it out.
turn on the unit and then tried to press the play button while the cd tray is in place. if doesn't work, unplug the dvd player then open the cover to access the internal part. look for a broken limit switch for cd tray mechanical assembly or check weather the cd not in proper place in the tray that is why an error occur.
Sep 02, 2012 | Televison & Video
My 360 will not read resurfaced games and many times i ctually have to hit it in order for it to open the disk tray. i was wondering if this could be caused by a faulty laser or dvd drive?
The disk tray often gets stuck with the older models of the Xbox 360. After opening the tray, lightly spray some WD-40 onto the areas where the tray moves along.
As for not reading games, it's important that you find whether the issue is the game or the Xbox. Try playing the game on another Xbox console. If it works, your DVD drive is most likely faulty.
Jun 01, 2011 | Microsoft Xbox 360 Console
Disk starts to spin but stops
If the DVD laser cannot focus on the disk, it will stop.
Either the DVD laser is faulty, the laser lens is dirty, or the DVD is defective.
Disconnect the machine from mains power and open the disc door. Dab rubbing alcohol onto a Q-tip and gently wipe the round white laser, which can be clearly identified sitting in the machine's disc tray. Wait for the alcohol to dry off the laser before reconnecting power.
Oct 21, 2010 | Sony PlayStation 2 Slimline Console
My husband always operated the DVD player. He has died and now I'm at a loss what to do. I rented a DVD at the video store. I tried to put it into the tray on the DVD player. I had to pull the tray...
Hi, Very sorry for your loss. As always the first step is to make sure the player is connected to the wall outlet and turned on. To put a disk in the DVD you should push the "Eject" button to open and close the tray it looks like a home(a triangle over a dash) on the front side of the box down left corner of the tray. You have the same button on the remote marked "Eject". Push either once, put the disk with the shiny side down on the tray and push the Eject button again to feed the tray back into the player. Usually the disk starts automatically and you will see a menu on the TV with alternatives like "Play the movie", "Setup", "Scenes",... you may highlight the "Play the movie" alternative, using "Up", "Down", "Left" and "Right" and then press the "OK" button. Or just push the "Play" button either on the box or the remote control. If you click "Here "you can download the manual in PDF form. To open it in your pc you'll need "Adobe Acrobat Reader" (or any other PDF reader) installed.
I will gladly answer your questions Best Regards Bruce
Aug 23, 2010 | Amphion Mediaworks S99 DVD Player
Philips DVP 5992 DVD player disk tray opens without a disk
it think you should open the unit up.get the cd.then try to play it again.
May 18, 2009 | Philips DVP5990 DVD Player
Pioneer DVL v888 disk tray will not open. There is a disk in it.
There isn't a way to open it by hand without removing the cover.
As for fixing the tray, there might be a few reasons why its not working. When you press one of the eject buttons, do you hear the usual whirring of motors? If you do and the tray still does not open, then the problem may be a broken rubber belt near the front.
If you don't hear the whirring of motors, then try playing the disk. If the disk does not play either, then the disk loading mechanism is out of sync and may require manually resetting it. This is accomplished by carefully pulling the spring loaded carriage upwards or downwards until it responds to the play button. Be very careful not to touch any of the exposed electrical components and capacitors, electrical shock may occur.
Apr 05, 2009 | Pioneer DVL-V888 DVD Player
E1 (rear) error. DVD tray will not open.
there might be a possibility that as soon as the tray closed the dvd shifted inside the machine. the dvd is stuck yes which means that the tray wont open because the dvd is blocking the gear turning. if so you are going to have to take it to your Dealership to open up the player and remove the disk. you can try it yourself but it's not recommended. tray gears will have to be tested to see if the tray will open once the disk is out though
Mar 29, 2009 | Philips Magnavox DVD/VCR Dual Player
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Nov 26, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Disc Error, and DVD tray ejecting on it's own....
If it is new, best advice is to take it the Comapny Service Centre, as you are having Warranty.
Apr 04, 2007 | Sanyo DVW-5000 DVD Player/VCR
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
