E machine ei3103, the dvd is not recognise by the computer
  • 284 Answers
There is not much to go on here but I will make a few assumptions.
If I am not accurate with my assumptions then my advise will not be accurate and you should clarify things.
You haven't mentioned which operating system you are using. The locations of the things mentioned below are similar for different version of windows but not identical.
Problem?
You may have a corrupt device driver.
The hardware may actually be broken
If it is a device driver.
If you open Control Panel -> Administrative Tools -> Computer Management then click on device manager you will see a list of devices categories.
If you have a category called something like Unknown Devices with a yellow question mark expand it. The devices in this group are not working. Hopefully there are not many devices in here. Identify the the one that is your DVD if you can and delete it.
Right click on the top level icon which will be your machine name and click scan for hardware changes. It should detect your hardware again and either use a pre-installed windows driver or ask you to pick one from a known location. If the device does not reappear in unknown devices then you should be good to go.
If it still does not function then you may need to find the manufactures web site and download a specific driver for your device. Go through the same procedure above but when detecting the device point the wizard at the driver you have downloaded.
Also don't be afraid to read the doco that comes with the driver :)
If it really is a hardware problem you should be able to pick up a new one cheaply or a second hand one even cheaper. (yay ebay)
Good luck and I hope this helps.
Posted on Jul 15, 2009
  • 358 Answers
Try this quick fix :
Get a screw driver, unscrew your machine and remove your drive. If you cant do this by yourself, just try and get a good technician to do it for you.
After this, power up your system normally without the drive connected.
Then shut down properly, and reconnect the drive, making sure that its firmly connected.
Then power on again and check it in the system BIOS if its now detected, then save and exit, then boot your system properly again.Then when the system boots, just right click on my computer, then properties, then select the hardwares tab, then click on device manager.
When you get to device manager page, try and locate DVD/CDrom Drives, then click on it, if your drive is there, then just right-click on it, and select uninstall, and after this, on that same page, click on 'Actions', and select "Scan for hardware changes". But if its not there. Just click on the "Actions, and Then select "Scan for hardware changes".
This should automatically out it back inside your My Computer page.
Hope this helps you out.
Hi my dell d610 does not recognise any dvd rom i
insert a good quality dvd in the drive. If no response, go to my computer and select dvd drive and double click, it may open. GL
Aug 19, 2013 | Dell Latitude D610 Notebook
SecurDisc HL-DT-ST DVD -RAM GSA-H55N ATA DeviceDevice not recogni
Your dvd lens needs to be clean from dust. Clean the lens of the drive by using a cd/dvd lens cleaner. You can buy it at any computer stores. Reconnect the drive from your computer.
Dec 19, 2009 | Computers & Internet
LG DVD recorder will not recognise any blank dvd's
The lasers do burn out, if nothing is reading, then perhaps the laser did burn out
Nov 02, 2009 | Electronics - Others
Sony VOE CD/DVD not recognised by the computer with vista
go to Acer web site download the vista driver for your sony voe cd/dvd.
Jun 23, 2009 | Acer Aspire 4315 Notebook
Why can't l play DVD's recorded on this recorder on other player
DVDs come in different versions.
Try using the -R DVDs. Once your DVD recorder finalizes the DVDs they should on any DVD palyer.
Check your manual to find out the finalizing method for your DVD recorder.
I hope this solution is helpful. Let me know.
Feb 11, 2009 | Samsung DVD-HR735 DVD Recorder/HDD...
Computer DVD/CD Drive does not recognise any discs
The most likely cause is a faulty DVD drive. Replacing the DVD drive is fairly simple.
You can buy a new one online for around $25 including shipping. If you need help finding a drive or installing a drive, I can help with that. Just let me know.
Jan 08, 2009 | NEC Computers & Internet
Dell computer won't recognise my DVD/RW drive.
http://kb.roxio.com/search.aspx?URL=/content/kb/General%20Information/000070GN&PARAMS=
download and run this file.. this should fix your problem buddy.
Nov 22, 2008 | Dell 16X DVD±RW Serial ATA Internal Drive...
My computer doesn't recognise my D: drive when I click on My Computer
Right click on 'My computer' and select manage and there you will find the option that is "Disk management".You can change the drive letter there..
Sep 04, 2008 | Lite On LiteOn 16x Black internal oem DVD...
Unable to burn using a LG GSA H58N DVD burner
With the built in drivers for windows XP it can identify and use DVD-RW facilities of DVD burner. However depending on your bios your machine can fail to burn DVDs if your bios can not recognise that output.
While loading the CD that comes with the DVD-RW did you get an error message if yes then it means you BIOS is failing to recognise your DVD-RW as an output method try to update the BIOS. But before you do that if you can try adding the drive on a modern (after 2002) machine with xp and see if it can burn DVDs there without adding any drivers.
if it fails on that other machine then you can be sure its not your BIOS but a problem with drive (which I suspect most actually). But if it works then then you need to update your machine bios.
Mar 25, 2008 | Computers & Internet
DVD PLAYS CD'S BUT WONT PLAY DVD'S
Aquarius0128 there are two things to consider here.. dvd's recorded on a computer need to be closed/finalized after you have recorded onto them in order to be used on a stand alone player.. they will play ok on original recorder because of the design of these machines finalizing prepares the structure of the disc so it can be recognised by other players as a dvd video disc.. you will usually see a 'finalize disc' option in your recording program
Second issue is this.. even if finalized an older (or even some modern) stand alone players will not recognise a recorded disc made on a computer or even if it can there are different formats DVD+R DVD-R and even DVD-RAM and DVD-RW (the two latter ones are rarely recognised outside a computer)
Jan 29, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
