Electrolux power head not working no power
There are four points of connection to get power to the nozzle, any one of which can cause this condition, or an on/off condition. They are the connections in the neck of the machine itself where the hose is inserted in front. The second is underneath the hose handle, where it connects to the two pronged sheath cord. The third is at the lower end of the sheath cord where the power nozzle cord connects. The last is the reset itself. That's what I check first when one of them is brought into my shop, because, believe it or not, most people don't know that there's even a reset there. If the little red button is sticking up push it down firmly but not hard. It's possible to push the bottom right out of the reset unit itself. If the nozzle doesn't activate after pressing the reset, start by disconnecting the power cord that goes to the wands. Check for blackened, enlarged connection openings, or charged, blackened prongs. If no problems found there, continue on up the handle checking each connection point for these conditions. If you find the problem at any of the connection points both parts must be replaced, the male and the female ends. That usually means replacing the cords themselves, as the ends are not available separately. If the power nozzle still refuses to run you or a qualified repair person will need to open it up to check the motor itself to see if it's any good. Once the faulty part,(s) are found and replaced it should start right back up and run normally.
